20 Most Recent
Kocaso M752 Dual Camera Android 4.0 ICS 512MB RAM WIFI 1.2Ghz 4GB Questions & Answers
Can't restore network connection
check your network connection
register to your network automatically
disable roaming
and check data connection is on in network connection
Screen is unreadable after charging battery on M752
take the tablet back to where you got it and get a new one if it has been to long get ahold of tech support for solutions and if there solutions don't solve the issue and you have owned it less than a year they will more than ikely send you a new one in return for the old one.
It won't unlock i can't open the tablet
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
Tablet will not turn on
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
