20 Most Recent
Activision Call of Duty: Black Ops Questions & Answers
How do you get ifinty money on multiplayer
Go on team tactical and kill your self 3 times if it doesn't work leave then find another team tactical match then kill your self 3 times again, but it has to be domination or demolition
My black ops game has no color the peopl
This may seem like a stupid question but, have you restarted your console? If not, do it. Did it fix it? If it didn't try installing the game on your console's HDD. Hope this helps.
Lazer burn
Hello,If the colors on one particular map are either blurred or not visible, it may be a coding error on your disc. This is easily fixable, as it only needs to be cleaned. If this is a problem for multiple maps, you may need to replace the disc or clean the laser on your XBOX. Either way, the cost of repair is less than $20. First and foremost, though, is to try and play another level and see if that problem is present.Hope that helps. Good luck!!!
When i try to search
The only reason why I think you aren't able to find any games is because your Nat is closed. to open your NAT try this
link. Also try to have your search preferences on fastest.
How do you find combat training on black ops
in your menu it should apear or look in your game folder see if it there or not if not then look on your game disk for it and install it from there or go into your game folder if you downloaded it from the internet and it should be there if no go to fenopy.com and click on the fenopy search and then type in that search bar for codbops and downloaded it to your pc it will be there ok !
I cannot enter a clan
There is something that you are entering in your clan tag that the system doesn't like. It may not look prohibited to you but it is flagging it for some reason. I would just try a different clan tag as there isn't really a whole lot you can do about it. If you are adamant about using the clan tag you can try to contact technical support. There is a forum located here and you can probably retrieve a phone number from the forum if you wish:
https://activision.custhelp.com/cgi-bin/activision.cfg/php/enduser/std_alp.php?p_sid=4h6balCj&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=&p_pv=&p_prods=0&p_cats=&p_hidden_prods=&prod_lvl1=0&p_search_text=&srch_btn_submit=%C2%A0%C2%A0%C2%A0Search%C2%A0%C2%A0%C2%A0&p_new_search=1&p_search_type=answers.search_nl
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000}
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
My xbox went rrrrrrrr and
This happened to me also. I checked with the store I bought it from and they said "the death ring" is caused by not placing the X-Box 360 horizontally. Evidentally the compression springs that hold the disc in place are not strong like WI and PlayStation for vertical operation.
I bought the new call of duty black ops back in
Just be gentle with the disc, keep it in the case or the console and don't leave it out too often. I don't think this is a normal issue though. If your xbox is causing the issue with other games too make sure you get it checked out. I wouldn't want you to ruin these expensive games.
