this is the only way to get rid of the orange light:
- Connect
- reset
- Blurr
- installation
- trouble
- settings
- service menu
- set
- channel
- parts
- instructions
- troubleshooting
- remote
- connection
- drivers
- blue
- repair
- manual
- bug
- CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by
meg_car on Jul 08, 2009
Vizio TV Repair
Power supply troubleshooting
Picture problem
Sound problem
Solutions (2)
Best Solution
That little fella is only turned off by
unplugging it. If all those little lights in America could be turned off
we could do with one less nuclear power plant. If unplugging it is not
an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv,
carefully pull off back cover. you will see two circuit boards one on
the left (Power) and one on the right (Video) on the Video board there
is a small plug on the right side with a yellow, white and red wire
going into a small white connector. the red wire is what controls the
orange light on the front. now that the plug is pulled turn it over and
you should see a small white plastic piece that holds each metal
connector on the end of the wires in. pry this piece of plastic up for
the red wire and pull at the same time, the wire will come out of the
connector. now tape the metal connector with electrical tape and tuck it
behind something or tape it to the chassis. plug your connector back
in. put the rear cover back on. now your tv will only show the vizio
logo in white when you have the power on. If you wish to disable the
logo for both orange and white just disconnect the white plug
completely.
