20 Most Recent
Acer Aspire One AO532H-2527 Netbook Questions & Answers
No wireless found
check for digital interference...if your settings are on...if it requires u to be signed in or some sort of security response
2002 cad. sls sev. r&r starter around the intake
You will need an Ubuntu Live boot CD, you can download from ubuntu's site. Burn to disc and Boot to it on your laptop.
- Once booted, select Try Ubuntu without installing.
- Open a terminal (ctrl + alt + t)
- type sudo fdisk -l
- This will show all your partitions, your main part should be the biggest usually sda1
- Type sudo mkdir /media/sda1
- Type sudo mount /dev/sda1 /media/sda1
- Now Type sudo chroot /media/sda1 to change to your disks context
- Now enter passwd <username> where <username is your login name, remember it is case sensitive.
- Now enter a new password twice.
- Now remove the ubuntu disc and reboot. Your password should now be the new one you created.
AO532H dont power up
I can't help you without more info? Is it plugged in? Have you tried another AC outlet? Have you tried another cord/charger? Remove battery? Has it beed damaged, or spill of liquid? Have you done a OS upgrade? etc, etc, etc.
How to delete history in firefox
At the top of your screen when first opening that browser, click on Tools. In the dropdown box, click on Clear Recent History. In the box that pops up, choose Everything, then put checks in the boxes for the things you want to clear (Browsing & Download History, Cache, etc.), and then click the button that says Clear Now. Hope this helps.
Black screen on ao532h-2527
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
