20 Most Recent
Westinghouse Electric LD-3255VX 32 in. TV Questions & Answers
Westinghouse codes
I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
My westinghouse ld-3255vx tv will
Can you count how many times it flashes ? It might flash like 6 times and pause for 2 sec and flash 6 times again. THen call a service comany and tell them this info and they might tell you what part inside is bad. They are not telling you this for you to replace but they might say something like oh 6 flashes is a Y board and we will have to order it.
Hope this helps
Fuse location
There is and normally it is located inside the power supply board, where the power cord goes in. But, watch out for hazardous high voltage even if the power plug is removed.
