20 Most Recent
Sharper Image SI655SIL Portable DVD Player Questions & Answers
I'm looking a charger for
I hope you can have similar charger for this dvd player at Radio Shack etc.
Take this dvd player with you and let them find suitable charger.
Thanks.
It comes up that there
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens(part of the optical assembly). It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual assembly failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track properly.
Dvd player
Go to radio shack maybe they got the cable you need to connect it,its a 3.5 mm to standard rca´s.Good luck
Key locked
on the right side you will see 2 green lights for charger and ac input, and a little slide that locks and unlocks it
I have a 7-in LCD sharper image television and the red light above the green light for power is blinking off and on what does that mean
A blinking red light on your Sharper Image 7-inch LCD TV usually indicates that there is a problem with the TV's power supply. Here are a few steps you can try to troubleshoot the issue:
1. Check the power source: Make sure the TV is plugged into a working power outlet and that the power cord is securely connected to both the TV and the outlet.
2. Unplug and reset: Turn off the TV and unplug it from the power outlet. Wait for a few minutes, then plug it back in and turn it on again. This will reset the TV and may resolve the issue.
3. Check the batteries in the remote: Make sure the batteries in the remote control are not dead and are installed correctly. If the remote isn't working, it could be the reason the TV is not responding.
4. Contact customer support: If none of these steps work, it may be a hardware issue. Contact Sharper Image customer support for further assistance or take the TV to a qualified technician for repair.
Keep in mind that the exact cause of the blinking red light may vary depending on your specific model of Sharper Image TV, and the manufacturer's troubleshooting steps may differ. It's always a good idea to refer to the user manual or contact customer support for assistance if you're unsure about how to proceed.
