20 Most Recent
LG E2350VR 23" Monitor Questions & Answers
I dont have a hdmi connection to my lg e2350vr
the dvi (or vga) connection from a graphics card to the monitor does not carry audio.
in this case, the cable doesn't matter because your monitor doesn't have speakers. it does have an 3.5mm headphone jack, but that is only to transfer sound if it had come in with hdmi cables.
if you want sound, you will need external speakers
Easy set package won't open. Monitor Driver won't install.
Hi mquinhoneiro,
I got the same problem. Probably there is something with EasySet Package. First time I installed driver + easyset like instruction said a I got "osd locked".
My solution:
1. Unistall your ati/nvidia driver with control panels
2. restart computer
3. you monitor probably will display 640x480 standard resolution
4. system recognise your vga card and install standard driver
5. restart
6. install lg driver depend on our monitor and connection
7. then should work. if not
b) install again but this time when you press install hold for 10 seconds menu button.
8. update driver from nvidia/ati site.
For me this help but easyshare wont install again. But I don't use it .
Anyway monitor is good for the price but have little "cool" colors (perhaps from blue lcd led).
My configuration for ~6500k setting
gamma 0
red 55 ( 60 if you want more red)
blue 55 (45)
green 55 (45)
brightness 48 saturation 70
Peter
LG E2350 monitor will not
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where in the power panel board, but you need to open the back cover of the television to enable you to check for the fault also be careful in solving the problem because it contain high voltage, if otherwise the power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this help in solving the problem......
The lg e2350 monitor is
You do not install drivers for each monitor but for the graphics card in your computer. Updating this driver may be your solution. (It is most likely made by Intel or AMD to help you find out what type of card it is).
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
