20 Most Recent Toshiba Satellite L655-S5101 Laptop Questions & Answers
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
2/17/2016 8:37:13 PM • Toshiba... • Answered on Feb 17, 2016
LAPTOP SCREEN WILL NOT TURN ON TOSHIBA SATELLITE L655 MODEL # PSK2LU-02Y00D
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
12/5/2015 6:39:26 PM • Toshiba... • Answered on Dec 05, 2015
Satellight L655 laptop wont turn on shows there is power but does nothing
Try this... Plug it in with the batter in while on mains. unplug and remove the battery Shut the computer off. re-plug the battery and restart the computer on mains. The battery is intelligent and can cause the system to fail to boot if it thinks it has failed.
3/12/2015 12:11:56 PM • Toshiba... • Answered on Mar 12, 2015
Whenever i click play to an internet video it not play..it does not even buffer
try using google chrome browser(latest version) as it will have latest flash player
5/3/2014 3:14:25 PM • Toshiba... • Answered on May 03, 2014
0answers
0answers
What can i do to fix my laptop to save files and download
You can test and fix it using Norton Utility (download and run it): http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
3/5/2014 11:48:19 PM • Toshiba... • Answered on Mar 05, 2014
0answers
0answers
Download google play store pc
Its pretty easy although before that you have to download Google Chrome, and use the online google store (specifically made for Chrome) to download Google Drive. That's the easiest way and with chrome it'll work flawlessly because it'll integrate into the browser as soon as your done installing it and enabling it.
1/23/2014 6:06:16 PM • Toshiba... • Answered on Jan 23, 2014
0answers
0answers
Screen blank
Be the first to answer 1/21/2014 11:25:32 PM • Toshiba... • Posted on Jan 21, 2014Be the first to answer
It goes dark, shuts off constantly. Battery meter
Unplug the battery and plug in the AC power plug into the laptop; Does the laptop start up and stay on? If yes, Then put the battery in WHILE IT IS ON; See if it starts charging. If it does not; You have a bad battery and need to replace it. If it does start charging here's what happend; Some laptop batteries if they are fully depleted on charge will not let you power up the laptop EVEN IF the power cable is plugged in. In some cases the PC won't turn on at all. The reason for this is because the battery must have a certain % of charge in order for you to start the PC even IF the power cable is plugged in. By removing the battery we eliminated the battery as being a cause for this issue; Once the PC is up and running in windows.. LET THE BATTERY CHARGE! You'll want at least 10% charge minimum for the PC to start up. If however the battery replaced still doesn't hold a charge it's going to be the AC Adapter power cable that's causing the issue. Best advice start off with the power cable replacement first; This is the cheapest to fix; Otherwise the battery can cost in excess of $50-$150 or more. But universal AC power adapters can be cheap $70 or less which varies depending on laptop.
12/9/2013 6:53:21 PM • Toshiba... • Answered on Dec 09, 2013
Toshiba Satellite L655-S5101 Laptop Logo
94 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
download google play store pc
  • Computers & Internet
