20 Most Recent
New World 90TC Electric Double Oven Questions & Answers
On the NW90 double oven.
Hi.
Sounds to me like the symbol represents a thermometer, which is for the main oven temperature.
New world 90TCgyro fan oven timer
From the New World Web site:
"How do I set my timer/programmer into manual when it is set in auto?
(5 & 6 button versions)
On your timer there are two buttons, which read "cook time" and "ready time". If your timer is in automatic, you can return it to manual by pressing these two buttons simultaneously. REMEMBER - if your oven is in automatic it will not work until the time you set it to come on or if you return it to manual."
Find more info on the link below:
http://www.newworldappliances.co.uk/Common-Questions_p18.aspx
My new world gas oven wont stay on. It ignites and warms up then the gas cuts out.
If an oven turns on but won't stay on it could be due to a faulty thermal fuse that trips if the oven overheats. If this is blown the oven won't turn on at all. One of the relays on the relay control might be faulty as well, in that case a new board is required. A faulty main control board is a common cause as well.
Bake and Broil Elements: These main elements can burn out over time. They can crack and get holes. Best to inspect them for damage.
Igniter: Igniters are the number one cause of an oven not turning on. Igniters open the safety valve and heat up to ignite the gas in the burner assembly. It can be tested with a multimeter for continuity and replaced if necessary.
I got this info from
https://www.electrafixbc.ca/appliances/stove.html.
