20 Most Recent Acer Aspire One 10.1" Netbook Computer - Onyx Blue (ao532h-2206) Questions & Answers
Where is the Wifi switch?
You can enable or disable your wireless with a combination of keys on your keyboard, or with a dedicated wireless switch. On Acer notebooks and netbooks, the following methods are used:
  • A dedicated button, located above the keyboard.
  • A toggle switch, located on the front or side of the device.
  • The FN and the key with the wireless icon on your keyboard. Usually, the key combination Fn + F3 is used.
10/25/2015 11:06:18 PM • Acer Aspire One... • Answered on Oct 25, 2015
Screen problems
I reset my acer to factory default now the screen is black and showing "starting set-up but never clearing screen
4/10/2014 5:57:02 PM • Acer Aspire One... • Answered on Apr 10, 2014
Change desktop background
control panel
12/10/2013 2:13:16 AM • Acer Aspire One... • Answered on Dec 10, 2013
My Acer Aspire One Nav50 won't boot. I hear there
I have a Acer Aspire One ao532h (NAV50) a with a black out screen new screen and flax cable it came on for 3 mins and the now not a thing what should I do ?
12/8/2012 4:59:03 AM • Acer Aspire One... • Answered on Dec 08, 2012
There's a lining in rigth side of my LCD. How do i
Sadly you will have to replace the LCD. Going to a trusted Acer Dealer (preferably the one you bought the laptop from) will help you get the best price on the LCD.
7/26/2011 11:27:49 AM • Acer Aspire One... • Answered on Jul 26, 2011
Use one of my photos for screensaver
All you need to do is save the phot to your photo file of "My Documents" then right click and select "Set As Background"
4/26/2011 7:30:22 PM • Acer Aspire One... • Answered on Apr 26, 2011
I've had my netbook for 3 months and I cracked the
Replacing a screen is really not that difficult. Make sure you power down and, I would suggest, removing the battery. The screen case should have little sticky rubber "buttons" over the screws that hold the front and back haves of the screen. Once those are removed there will be clips that will still hold your frame together. With a small screw driver you should be able to insert and carefully locate those clips and work them loose, that will probably work best going from top center and work your way over and then down the sides. Once you have the "frame" loose there will be some more little screws and a couple of ribbon cables with ZIF connectors (zero insertion force) usually they have little clips on either end where they are plugged in and just pull those clips back and the cable will slip right out. Lastly there will probably be some 2 sided tape once all the screws have been removed. So you will still need to "pry" the screen from the back 1/2. Then just replace with your new screen and reverse the steps. Just make sure the ribbon cables are seeded well and the clips are closed again.
I would also before closing everything back up reinstall the battery and do a quick start up to verify its function before you get everything back together.
Happy hardware and good luck!
4/15/2011 3:51:18 PM • Acer Aspire One... • Answered on Apr 15, 2011
My acer aspire one series is connected to wireless
are you sure the modem/adaptor is is turned on and your browser is functioning properly
3/31/2011 4:15:24 AM • Acer Aspire One... • Answered on Mar 31, 2011
3answers
I have an Acer Aspire
It means that the Operating System on the machine is corrupted. You can fixed the problem by reinstalling a new Operating System on the machine. First you need to have the OS Cd of your machine. Second you need to set the CDROM as the First Boot Priority. To go to BIOS Restart the computer and immediately press Del or F2. Go to BOOT tab then select the CDROM as the First Boot of the Machine then save the settings.
Thanks for using Fixya.
2/1/2011 6:12:03 AM • Acer Aspire One... • Answered on Feb 01, 2011
2answers
Wont boot up after an
Try tapping F8 while booting and go to boot with "last know good configuration" if that doesn't work hit f8 again while booting and go to "safe mode" and do a system restore :) hope this helps thanks
12/30/2010 10:59:46 PM • Acer Aspire One... • Answered on Dec 30, 2010
Acer aspire one netbook. The screen has a line
The Strip of display is bad. Need replacement. Ask for replacement if its still under waranty cover
11/30/2010 8:20:04 PM • Acer Aspire One... • Answered on Nov 30, 2010
2answers
Access outlook
what password computer or outlook Reset an Outlook password to keep your program secure. A Microsoft Outlook password keeps your email account secure from unwanted intrusion. When you wish to reset your Outlook password, you must perform a multistep process to change your password first with your Internet Service Provider (ISP). The password with your ISP mail server must be the same as the password you set in your Outlook program in order to send and receive emails. Call your ISP and request a new password for your account. Write down the password after you receive it to ensure you do not forget it. Open your Outlook program, click the "Tools" tab and then select "Email accounts." Select "View or change existing email accounts" and then press "Next." Highlight the email account you wish to change (if you have more than one email account) and press "Change." Enter the new password you just received from your ISP into the appropriate fields (entering it twice). Place a check mark beside "remember password" if you want Outlook to remember your password each time you log in. Click "Test Account Settings" to make sure your account works with the new password. Press "Finish." I forgot my Outlook password http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
12/25/2023 6:14:52 AM • Acer Aspire... • Answered on Dec 25, 2023
Acer Aspire E1 571 not charging battery.
Question edited for clarity and toss in a few CAPS. Question moved to Acer Aspire category. There a few issues that can cause this, the obvious one is that the battery has failed internally, but it can also be a charging software issue. Try this. Unplug from the mains supply. Remove the battery. Leave the computer for 2 hours. Press and hold the power button for a full 2 minutes. Replace the battery, plug back in, count to 10 and power it back up. Has the motherboard battery ever been changed? They are critical to the health of the motherboard and the machine in general.
Aspire E1-571 Plugged in not charging
Acer Community https://community.acer.com > ... > 2016 Archives Aug 20, 2016 - Hi, I have been having a quite critical issue with my laptop recently.
Acer Plugged In Not Charging
Driver Easy https://www.drivereasy.com > ... > Common Errors Apr 21, 2021 - This plugged in not charging problem may occur if you are using the wrong battery driver or it's out of date. So you should update your battery ...
Acer E1-571, Charging problem
Tom's Guide Forum https://forums.tomsguide.com > threads > acer-e1-571... Feb 10, 2019 - Hi there, I have a acer e571 laptop and i am facing a battery charging problem, whenever i plug in charger it start charging for 10 to 15 seconds and start. 1 answer ยท Top answer: It could also be the charger. The fact that moving the cord made a difference makes me think it might be. Also, have you tried charging it when the laptop ... My acer e1 570 laptop won't charge - Tom's Guide Forum Feb 7, 2017 I have an Acer Aspire E1-571-6837. It will not charge the ... Aug 25, 2016 Hi my acer aspire E1-571 won't turn on. I plugged it in and it ... Mar 9, 2018 More results from forums.tomsguide.com ..
12/3/2023 3:18:23 PM • Acer Aspire... • Answered on Dec 03, 2023
My acer aspire m5100 desktop will wont do a start up beep and nothing on the screen
If you have no internal hard drive installed you won't get it to work correctly as the hard drive is where the data is stored for the operating system.
10/2/2022 2:12:57 PM • Acer Aspire... • Answered on Oct 02, 2022
Prendo la pc acer y se apaga vuelve a prender y se apaga y asi sigue
Estimado Carlos, Cuando la PC se apaga poco tiempo despues de terla prendido puede ser una senal de sobrecalentamiento del procesador. Si es una PC desktop, puedes verificar si el disipador de calor de aluminio y su ventilador estan colocados correctamente sobre el procesador y si el ventilador esta' funcionando. Si es una laptop, debes verificar si cuando la prendes el ventilador de las rejitas de ventilacion esta' suenando. Un ventilador que este' parado o con baja rotacion puede ser una de las causas del sobrecalentamiento. Pero, en los dos casos, si no es problema del ventilador del procesador, lo que hay que hacer es lo siguiente: 1 - Desarmar la computadora, y sacar el disipador de calor com mucho cuidado de sobre el procesador; 2 - Limpiar bien entre las ranuras del disipador de calor, sacandose todo el polvo y suciedad del mismo ya que el polvo ayuda a mantener el calor y sobrecalentar el procesador; 3 - Limpiar muy bien las rejillas de entrada/salida de aire, sacandose todo el polvo y suciedad, 4 - Rearmar el disipador sobre el procesador, pasando entre ellos una delgada camada de pasta termica plateada, que se puede comprar en tiendas de suminsitros y partes de computadoras (NOTA: no instale el disipador sobre el procesador sin pasar la pasta termica, porque podra' seguir sobrecalentandose); 5 - Rearmar la computadora. Caso usted no tenga facilidad en armar y desarmar la computadora, seria bueno contactarse con un tecnico de su confianza para hacer ese trabajo para usted. !Espero que esa respuesta pueda haberle sido util! PD.: Como ese sitio web solamente accepta caracteres en Ingles, la acentuacion no puede ser utilizada normalmente... Saludos, Miguel Luiz Martins
6/30/2022 3:55:50 PM • Acer Aspire... • Answered on Jun 30, 2022
Not receiving a video signal (VGA or HDMI) from an Acer i5 Intel H57 Motherboard H57D02G1 1.0-6KSMHS1
OucH no acer real model PC told at all wow hard nut to crack that, I sure can not guess that ...The case told only helps if power on button is wrongor the PSU is wrong. I moved this to acer forum. as the mobo matters.Q1;never worked before by you,? this acer mobo by you?or found it used and dead.? used mobo come good bad or a wreck. (history not told , as in when did fail)the acer.com is the place to look first. for manuals. not told what GPU are you using onboard vga or GPU card or what?All fans spin ? CPU and PSU????if using GPU card that has fan, does it spin too??if case fans do they spin?DoeS DVD tray eject (button hit)?DOES PC beep or flash LED codes?Q2;What VIDEO port class is this "connection"is it:vga, hdmi, dvi or DP ports which one, and where is it? For now only use (if has one) use the VGA port on the mobo , no PCI cards in slots., NO HDD, AND NO DVD DRIVE (JUST UNPLUG THEM FOR NOW) ALL USB THINGS UNPLUG, KEYBOARD LEAVE THERE.MEMORY :pUT 1 stick of ddr RAM only in bank0 channel "A"CPU socket pins bent as seen on ebay endless and sad. below is me guessing what Acer you have.and find this, Acer/GATEWAY ZX4951 or ASPIRE Z3100I read the GW manual check jumpers.the PSU needs 2 power cables to the mobo.4pin power and 24pin (or 20 on legacy)or mobo will be dead. why mess with ACER. (they have no service manuals)put an Asus or Gigabyte mobo there and end this ACER pain,post a photo of the mobo and we can guess what PC it came out of, .......
6/4/2022 5:10:37 PM • Acer Aspire... • Answered on Jun 04, 2022
I've had my Acer Aspire V5-531 for about seven months now and it recenetly started to make a loud humming noise every time I pick it up or just move it a little bit. It's usually going on for
mute the speakers if still sounds noisy the fan inside is packed in lint and needs to be cleaned out or overeheating is bad news. why not ask a shop to look into this. we can take it apart (covers ) and user or stethoscope to hear noise. a $5 tool that is. and all shops have one or DIY one. I put my hear to hDD casings me, i use tube and put it near the fan vent to hear it scream. there is no other way besides unplugging all that 1 by one to hear it go silent. this is SOP, vast PC's pack up in lint and fail.
5/27/2022 5:04:29 PM • Acer Aspire... • Answered on May 27, 2022
2answers
I keep getting a message popping up saying I have a problem then the app shuts down, its a new laptop and its never been used before, I downloaded the app to watch my dvds, the message says my code is
Sounds like the application is not installed correctly, uninstall it via control panel and re install from the original disc or download. If you don't have this available, you can use an alternative player, I personally use VLC and prefer it, more info here: VideoLAN Official page for VLC media player the Open Source video framework Or direct download if you prefer: http://get.videolan.org/vlc/2.1.5/win32/vlc-2.1.5-win32.exe
7/2/2021 11:21:42 AM • Acer Aspire... • Answered on Jul 02, 2021
Acer Aspire One 10.1" Netbook Computer - Onyx Blue (ao532h-2206) Logo
18 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
wifi switch
  • Computers & Internet
