20 Most Recent
ASUS N73JQ-A2 I7-740QM Notebook Questions & Answers
Hello system hangs up before
bios reset is not for the normal user. and, if the pc is more than 6 years old, likely it won't help your problem. get a new pc if it is an old one.
regards,
Webcam
In what? the Asus supplied software? I don't know what software Asus has , maybe CyberLink? Look in All Programs, open software, does it see the webcam, in settings? You can open Device Manager, Imaging Devices, Is it listed? enabled? Webcam drivers can be found here:http://www.asus.com/Notebooks/Multimedia_Entertainment/N73Jq/#download
Asus N73SV-FHD-TZ087V
Your description is glare.Waht means funtion keys? Shorcut = right click WMP on the Start Menu and "sen to the desktop"
The screen on my laptop
Two things to try until youre sure its some serious hardware problem.
Firstly hold the power button till its totally off. the click the power button three times?
If it doesnt work, disconnect power source, take off battery, and hold power button for 30 seconds. replace everything and start.
If you hear the fans turn and some sounds from the computer but the screen is still off, you may have to replace the screen. only a professional should handle that.
kc
Asus N45SL stucked on Jay Chou logo
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
