20 Most Recent
Trendnet TEW-650AP Wireless Access Point (TEW650AP) Questions & Answers
Can't ping internal page
It may be that the WAP was set-up to use a different subnet from the default. Check the IP address that is assigned to the computer that is connected to the router and substitute the first 3 octets (192.168.10 is the default) with what your computer reports. So, if your computer has an IP address of 192.168.22.32, then use 192.168.22.100 instead.If that doesn't work, you will probably have to do a factory reset on the device to get it to use the default address.Downloads for this device are available here: (
click here)
2/8/2012 5:13:21 PM •
Trendnet...
Answered
on Feb 08, 2012
Screen blacks out on KVM
I have had this happen to me a few times. Usually it is the video card/driver. By KVM I assume you mean a KVM switch that goes to both computers, so you can switch between them? I have had trouble with them, too, so try putting the VGA straight to the monitor and see.
12/21/2017 1:25:51 PM •
Trendnet...
Answered
on Dec 21, 2017
Wi fi pasword
If you want to reset your wifi so you need to press wifi reset button click on it and hold about 20 seconds.
1/29/2015 7:40:06 AM •
Trendnet...
Answered
on Jan 29, 2015
How do I set a static route lan side on a tew-733gr
You need to download the user guide from here
TRENDnet Support
Basically
1. Make the computer or network device (for which you are establishing a DMZ link) has a static IP address (or you can use the DHCP reservation feature to ensure the device has a fixed IP address) (see "Set up DHCP reservation" on page 29).
A. Signing up for a Dynamic DNS service (outlined in the DDNS section) will provide identification of the router's network from the Internet.
2. Log into your router management page (see "Access your router management page" on page 22).
3. Click on Access, and click on Firewall & DMZ.
4. Next to DMZ Enable, click Enabled.
5. Next to DMZ Host IP, enter the IP address you assigned to the computer or network device to expose to the Internet.
6. To save changes, click Save Settings.
1/23/2015 10:50:47 AM •
Trendnet...
Answered
on Jan 23, 2015
