20 Most Recent
Acer Aspire 5336-2283 Notebook Questions & Answers
5336 as[ire when turn on screen is going to white comletely when screen movie up and down then iz working
This is actually pretty common and not really regarded as anything by the manufacture, if this ONLY happens for a brief moment during start up you're fine, typically a chip set update will solve this issue but it really isn't causing any harm so make sure you know which chip set you need. If it continues to happen for awhile even after boot up, re-seat your LCD cable (CAUTION! : making an error while doing this could cause you to break the LCD panel)
Connection vga for bush led tv
Clarify your question? Are you going from your VGA out on your notebook and you want it to be plugged in to the HDMI input? you should have a vga input on your led TV. if you still want it to run on HDMI, then you need an adapter from VGA male to HDMI, you can find it on amazon.comTony Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/tony_a41fa0b801734e2f
How to video on remove 3v batt from aspire 5336
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Acer Aspire 5336 boot/screen/ram problem
Yeah, sounds like a ram problem. You can try re-seating it by pulling it out and putting it back in or its very possible the ram has gone bad and you will need to replace it.
How to activate bluetooth in Acer Aspire 5336
Have you installed a Bluetooth driver for your specific
laptop model? There should be a CD coming with your laptop that has all the drivers you need for it and probably for other models as well..
Also check if u even have a
Bluetooth device built-in in your laptop.
Turn-on your bluetooth icon, the installation process will start
automatically, and after all click on "OK" button to finish all steps.
When you are installing driver on your system, it may be possible that
software ask you to activate bluetooth option, never close this window
before OK.Feel free to get technical assistance at , if the same problem is still occurring....
http://www.vtechsquad.com/acer-support/
NO Bluetooth Devices
Have you used BT on this laptop before ? BT can be disabled/enabled in the BIOS, Windows, and often, depending on the Manufacturer, via the keyboard. ALL must be 'enabled' for it to work.
I have problems with the ram in my laptop what can i do? how can i find out if its a hardware problem or software
To check if you have a RAM problem, go into the BIOS and check the amount of RAM installed, does this match the total amount of RAM installed, if the RAM in the BIOS does not match the total amount of RAM in the RAM modules then you may a faulty RAM module or an incompatible RAM module.If it is a software problem, a program may require more RAM than is installed on your computer. The software instructions will recommend the amount of RAM your computer should be installed with.
