The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
What are you recording from? If using a condenser mic and you fail to turn on the Phantom power, symptoms such as you describe would occur. You don't include enough information about your setup to allow us to help.
If they are angles wit slotted holes, they probably mount to the sides for use in mounting the unit in what sometimes is called a relay rack that accepts 19 inch panel width devices. Many EQ's and other devices have this option. Yet other options if your brackets are tapered, they attach to the bottom to tilt the unit to a convenient angle. If you don't need either of these options, store them away for when you do or if at some point you want to sell the unit complete.
Scroll down to the link "Get Manual" and click on it. They will only let you do two downloads a day unless you are registered.
On page 9 (specifications) the type of signals are spelled out. Note that Behringer SOMETIMES uses a pseudo balanced line where one side is "floated" with a resistor to ground.
Also download this which will have SIMILAR circuitry:
You will need an oscilloscope and a good grounding in electronic servicing to attempt a repair.
But, check the signal routing. Refer to the user manual.
It sounds like you're experiencing a couple of issues with your Behringer Xenyx 1204FX mixer. Let's address each of these problems separately:
DSP Display Not Illuminating: The fact that the DSP display works when you press down and turn the knob suggests that the issue might be related to the display itself or its connection. Here are a few steps you can take to troubleshoot the problem:
Check Power Source: Ensure that the mixer is receiving proper power and is turned on. Sometimes display issues can be caused by power-related problems.
Connection: Make sure the ribbon cable or connector that connects the display to the circuit board is properly seated. A loose connection could be causing the display to not illuminate.
Faulty Display: If none of the above steps work, there might be a problem with the display itself. You may need to contact Behringer support or a professional technician to get the display repaired or replaced.
AUX 1 Send Not Working: If the AUX 1 send is not working as expected, there could be several reasons for this:
Routing Settings: Make sure that the AUX 1 send is properly routed to the desired destination. Check the routing options on the mixer to ensure that the signal is being sent to the correct output or destination.
Level Controls: Verify that the level controls for AUX 1 are set correctly. Make sure that the AUX 1 knob for the specific channel you're working with is turned up.
Effects/Processing: If you're trying to send a signal with effects applied, check if the effects are set up correctly. Sometimes, an incorrect effect or routing setting can affect the AUX send.
Cable and Connections: Ensure that the cables connecting the AUX 1 send to external devices (such as monitors or effects units) are functioning properly and securely connected.
AUX Master Level: Confirm that the AUX 1 master level (usually located on the main output section of the mixer) is turned up to an appropriate level.
If you've gone through these troubleshooting steps and the issues still persist, it might be a good idea to consult the user manual for your Behringer Xenyx 1204FX mixer for further guidance. If the problems continue, you may need to reach out to Behringer support or consider seeking assistance from a professional audio technician or repair service.
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty
Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects
I hope you can solve the problem, comment the results
Greetings Franco Dosil
Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios
Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos
Espero puedas solucionar el problema, comenta los resultados
Saludos Franco Dosil
https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdfhttps://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
Check all the wiring connections on the speaker. Check the plug in points for the cables are not loose in the body of the speaker or the connector plugs themselves are not loose in the actual plug sockets.
Next you will need to get inside the speaker body to check the connections and soldered joints. Take a good look at the back of the cable plug sockets and to the back of the actual speaker cone connections. Check each wire at Both ends for damage. No sound at all suggests the issue might be at the 'Input' where the cable plugs into the back of the speaker body.
If the right input on your Behringer Ultracoustic ACX1800 CD is not working, it could be due to a number of reasons, including:
A faulty cable or connection: The problem could be as simple as a loose or damaged cable. Try swapping out the cable with a known working cable or check the connection to ensure that it is secure.
A blown fuse: The ACX1800 CD has a built-in fuse that protects the internal components from power surges or other electrical issues. Check the fuse to make sure it is not blown and replace it if necessary.
A damaged preamp or amplifier circuit: If the problem is not with the cable or fuse, it could be due to a damaged preamp or amplifier circuit. This can be caused by a number of factors, such as overheating, power surges, or other electrical issues. In this case, you may need to take the ACX1800 CD to a professional repair technician to diagnose and fix the problem.
A faulty right channel input jack: It is also possible that the right channel input jack itself is faulty. This can be caused by wear and tear over time or physical damage. In this case, you may need to replace the input jack or have it repaired by a professional technician.
Based on my research, the Yamaha PMH5000 mixer features two 1/4-inch "insert" jacks for connecting external effects processors, such as compressors or equalizers, to individual channels. These jacks are not intended for connecting external power amps.
However, the PMH5000 does have two "main out" jacks that can be used to send the mixed audio signal to external power amps. These are typically located on the back of the mixer and may be labeled as "L/R" or "Main Out."
When you connect an external power amp to the main out jacks, the signal is sent directly to the power amp and is not routed through the internal power amps of the mixer. The external power amp then amplifies the signal and sends it to the speakers.
It is important to note that when using external power amps, you should adjust the volume levels carefully to avoid damaging the speakers or the power amp.
I'm sorry, but without additional information such as a schematic or a more detailed description of the location of the components, it is difficult to determine the exact values of D51, R26, and C33 in your Behringer B815neo speaker. It is recommended that you contact Behringer customer support or a professional audio repair technician for assistance with repairing your speaker. They may be able to provide you with the necessary information and guidance to identify and replace the damaged components.
Bummer dude. Sounds like a capacitor or processor problem. Behringer stuff is really not very repairable.
I have had to scrap lots of the stuff over the years.
Great while it works and very affordable
