20 Most Recent ASUS RTN10 wireless router Questions & Answers
2answers
I have lost my asus router RT-N10U password how can i get it back
You can reset it to factory default settings by pressing the reset button and type a new password by accessing the router.
9/30/2019 10:53:53 AM • ASUS RTN10... • Answered on Sep 30, 2019
Router keeps losing WAN conection, but led lamp is blinking...
maybe new aerial finds more wifi hot spots, mine started doing that when i changed router port forwarding. but if in doubt just press reset button for 10 secs - might need to se paper clip and look hard around router for a little hole to stick it in.. ...lol
7/12/2017 8:07:10 AM • ASUS RTN10... • Answered on Jul 12, 2017
My router did not come with any software do i need
Please reset the router by placing a pin in reset hole and push the pin sslightly, (remember you need to do this when the rrouter is in ON state)
Then connect your router to your computer using ethernet port (this is for configuration) and also connect the ADSL cable.
now open internet explorer and type in //192.168.1.1
Then it will prompt you for username and password
Username: admin
Passsword: password
this username and password is by default.
then configure your router as you need by changing display name, password authentication, MAC registration etc...
If you face problem with connecting internet even following the above steps, then you need to contact ISP(internet service provider) for settings.
Thanks,
Satheesh
4/27/2017 6:50:24 AM • ASUS RTN10... • Answered on Apr 27, 2017
How to connect two ASUS RT-N10 Routers to PPPoe connection?
All routers don't work the same. You have assigned to the second router to an IP address that is outside of the pool. Some routers will not see this. Try assigning the second router to the .50 IP and see if it is identified. If so, you know that is your problem. You can then decide to either reassign the second router's IP to a high address in the pool, or use the .50 IP and in the first router, use the advanced settings to reserve the .50 address to the second router so it will not re inadvertently assigned to another device, causing an IP conflict.
4/27/2017 5:44:09 AM • ASUS RTN10... • Answered on Apr 27, 2017
WHY DOES ASUS RT N10 NOT RELEASE DNS ONLY TO A WINDOWS 7 PC
Make sure your windows 7 pc internet connection is set to obtain DNS server's automatically .(From your router)
7/24/2014 6:19:30 PM • ASUS RTN10... • Answered on Jul 24, 2014
The wireless is ok but if theres black out when the power is back my wireless is not working
First I suggest you get a UPS and attach ALL your devices on battery backup. Power surges/power interruptions could be detrimental to your electronics. After a Power Interruptions ALL your devices may have to be rebooted one by one, allowing each to selftest. If you live where the power goes off often or electrical storms are common, it's crucial to use Surge protectors and a Universial Power Supply.
4/26/2013 8:45:59 PM • ASUS RTN10... • Answered on Apr 26, 2013
We been pressing the wps button at the back but still not working.
Here's a video Miguel Gonzalez suggested as a solution to your problem from YouTube:
How to connect any WPS-enabled wireless device to a wireless modem, router or access point
4/24/2013 1:54:53 PM • ASUS RTN10... • Answered on Apr 24, 2013
I am adding a wireless printer how do I find my network key?
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
2/17/2013 11:31:28 AM • ASUS RTN10... • Answered on Feb 17, 2013
Asus wireless router password change sol
connect to your router via ethernet cable and open your web browser. In the address bar type 192.168.1.1 which should bring up the router settings page. for user and password type in admin for both. Then navigate to the password settings and change it and save the changes.
11/9/2012 5:37:34 PM • ASUS RTN10... • Answered on Nov 09, 2012
Display wireless router password
Re-set you modem to default setting by pushing and holding the reset button. OR Download Wireless Key View at this site, scroll down near the bottom of page: http://www.nirsoft.net/utils/wireless_key.html
11/3/2012 1:09:55 AM • ASUS RTN10... • Answered on Nov 03, 2012
Find wireless password
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key. When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
11/1/2012 11:00:23 AM • ASUS RTN10... • Answered on Nov 01, 2012
ASUS rtn10 wirelles preoblem
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key. When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address
8/28/2012 12:03:05 AM • ASUS RTN10... • Answered on Aug 28, 2012
2answers
Router stops working if mozilla firefox 4 is
A browser can not affect your router. Some thing else would be th cause I would suggest upgrading the firmware to your wireless router.
5/3/2011 10:57:43 PM • ASUS RTN10... • Answered on May 03, 2011
2answers
Hello....how i can reset the password of the
Check for a reset button on the back of the router. this should reset everything and you can go through the setup process again. default username upon resetting should be admin and password is probably blank. If you have any more problems respond back and ill see what i can do.
Sean
4/1/2011 4:31:51 PM • ASUS RTN10... • Answered on Apr 01, 2011
I just installed this router.
Access your router with insturctions below then find the security tab and decide what type security you want.
The only secure encryption is WPA2.
When you allow WPA-TKIP to be run alongside for compatibility, you just eliminated the only security you had.
All of the other "security" methods for a home router are useless. Disabling or altering the SSID broadcast does not protect the connection from anything, and neither does MAC filtering. Both are trivial to get around, and are more useful for administrative purposes such as load balancing between multiple access points on a network.
To open the set up page of the router of the router , one of your computer should be able to go online through the router.
It could be a wired computer or wireless computer.
If it is a wireless computer then make sure that the computer is connected to your own wireless network.
Do not change any wireless settings on the router using a wireless computer.
OK ! Now you have a computer online through the router and you want to open the set up page of the router.
First step is check the IP address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd in the RUN box==> click OK or Hit ENTER . You will see a black window that is a command prompt . In the black window type in " ipconfig " ==> and Hit ENTER on your key board .
For Windows Vista and Windows 7
click on START ==> type in cmd in the start search box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of information. Try to find out the local area connection IPv4 address .
Note down the Default gateway number.
For MAC OS
Click APPLE icon in the right top corner of the computer. Go to System Preferences ==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is connected. If you go to that you will find the Ip address and router Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up page of the router
Now you got the IP address of the router.Open the Internet Browser ( Internet Explorer, Firefox, Safari )
In the Address bar of the browser Type the IP address of the router.
Do not type http:// or www just type in the IP address only.
It will ask you for the user name and the password of the router.
This is the User name and the password of the router and NOT the wireless password. On a wireless router, there are 2 passwords. One is to access the router and the other one is for the wireless network.
For most of the routers the default password will be " admin " . for some routers the default password is " password ". For Linksys router the default password is admin and no user name.
1/25/2011 2:48:51 AM • ASUS RTN10... • Answered on Jan 25, 2011
How do I launch the "web browser"?
For Windows XP
For MAC OS
1/23/2011 2:12:03 AM • ASUS RTN10... • Answered on Jan 23, 2011
Help
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
1/22/2011 2:57:08 PM • ASUS RTN10... • Answered on Jan 22, 2011
ASUS RTN10 wireless router Logo
37 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
router did not come any software need
  • Computers & Internet
