20 Most Recent Polaroid FLM-3201 Television Questions & Answers
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
I agree with tom you need to replace all the electrolytic capacitors. It is not that difficult if you know what you are doing. If not take it to a tech savvy friend..
8/26/2017 2:09:04 AM • Polaroid... • Answered on Aug 26, 2017
0answers
I have a TLA 04641C serial # BR8B0505560002883 Polaroid TV
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
7/2/2017 2:28:04 PM • Polaroid... • Answered on Jul 02, 2017
Picture takes almost an hour to come on
Replace swollen capacitors on power board.
2/8/2016 6:52:50 PM • Polaroid... • Answered on Feb 08, 2016
0answers
When i turn it on it shows ...NO SIGNAL VGA INPUT ... cant get it to do anything else
if all the other inputs are working then the trx rcv IC's have gone bad in the module. you can buy a replacement module they are easy to replace contact me and i can get you one.
4/2/2015 9:10:58 PM • Polaroid... • Answered on Apr 02, 2015
Tv comes on, then as soon as the screen name comes up, it kicks off?
This is a power supply issue there are some Capacitors that need to be replaced
2/20/2015 10:22:03 PM • Polaroid... • Answered on Feb 20, 2015
Wherecan i buy a power supply for a polaroid flm-3201 tv.
CAll Me 3525840491 i have several
2/20/2015 10:21:12 PM • Polaroid... • Answered on Feb 20, 2015
7answers
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
9/2/2014 2:12:14 AM • Polaroid... • Answered on Sep 02, 2014
I have a Polariod 32in, Screen Flickers while on!
29V instead of 24V means, the backlight inverter board is not working properly. When it starts work properly, this 29V will drop to 24V. It is the clear evidence for improper funtioning of the back-light inverter. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
6/5/2014 8:57:26 AM • Polaroid... • Answered on Jun 05, 2014
I have a polaroid FLM3201 flat screen tv how do i get these weird loking smudges off the screen?
i had similar probs with my lcd... my speakers were too close to my tv !
5/21/2014 8:08:17 AM • Polaroid... • Answered on May 21, 2014
0answers
Remote code
Be the first to answer 1/28/2014 3:04:17 AM • Polaroid... • Posted on Jan 28, 2014Be the first to answer
3answers
When I turn on the tv the word Polaroid appears
Hi there, I don't completely agree with the previous opinion. The problem lies not in the lightst....he caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped(or not) please rate, thank you!ecd8d91.jpg
11/22/2013 1:04:37 AM • Polaroid... • Answered on Nov 22, 2013
0answers
Polaroid 32 flat screen turn on lights up polaroid screen goes black
try replacing the bulb in the tv
2/22/2013 11:39:35 PM • Polaroid... • Answered on Feb 22, 2013
My porlaroid tv will not trun on
Hello,The Polaroid FLM-3201 units have a known issue with the filter capacitors on the power supply board. When the filter capacitors go ou tthe power supply can not start up so you get no power to the TV. New boards are not available any more but you can repair the board in your TV by replacing the filter capacitors. If you can a little soldering then you can do the repair yourself. Here is a picture of the power supply board with the filter capacitors circled in yellow and below the picture is a link to get a kit of the needed capacitors.12_8_2012_2_55_24_am.jpghttp://www.ccl-la.com/catalog/product_info.php?products_id=239I hope this helps,BuddyMc
12/8/2012 2:56:29 AM • Polaroid... • Answered on Dec 08, 2012
Polaroid FLM-3201 Television Logo
160 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
polariod 32in screen flickers while
  • Televison & Video
