20 Most Recent
Epson P-3000 (40 GB) Digital Media Player Questions & Answers
Epson P-3000 image/multimedia viewer will
Welcome to Fixya. Updating the Firmware would have resolve the issue that you have but it don't. If epson says that you need to send it for repair it does not means that this is just a problem with the hardware. Sending the device to epson would be better so that the can check if this is a problem with the software or hardware then they will replace or fix the issue with your viewer.
Thanks
How do i get my craig cmp1226e to advance to the
the little wheel at the top on the left side roll it to the right to advance to the next song. hold it to the right to advance quickly, and roll it to the left to go to the previous song. Push it straight down to get to the roo menu.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
