20 Most Recent Frigidaire FRT18S6J Top Freezer Refrigerator Questions & Answers
Make sure the seals on your doors are in good condition. Also check that the fridge is turned to a correct temperature and not too warm. Also ensure that the freezer is performing as expected as poor performance may indicate a drop in the appliances capacity. Check that the back of the fridge has reasonable airflow around it as this can restrict capacity also.
Frigidaire... | Answered on Mar 13, 2011
There is some truth to it. Refrigerant needs to flow from high pressure to low pressure, and refrigerant pressure is directly proportional to temperature. Once the temperature drops below 40*F, for the outdoor coil, refrigeration efficiency is lost. Some heatpump units need auxiliary heat because.
Cold refrigerant condenses, into a liquid, and a compressor will not compress liquid, why its valves and internals would chatter into pieces. There is such thing as compressor crank case heaters, or belly band heaters. A heater removes, evaporates liquid refrigerant from within a compressor, it is protection.
I would get a compressor heater, wraps around the compressor belly, near 50 watts, and can use a relay to switch off the heater when the compressor runs, or let the heater work continuously.
Frigidaire... | Answered on Nov 09, 2019
I DON'T KNOW. PERHAPS MOVING ARM UP AND DOWN A FEW TIMES - THEN UP AGAIN MIGHT
RESET CLICKER. IF NOT, TRY UNPLUGGING AT WALL AND MOVING ARM AGAIN.
Frigidaire... | Answered on Oct 26, 2019
The LED above the Ice Off icon should be lit when the icemaker is disabled. It should be off when you want ice from the icemaker. To toggle the setting, press and hold the Ice Off touch pad for 3+ seconds. This is shown in the manual for the FPHF2399MF2 on page 14. Sears Parts Direct has the manual here: https://www.searspartsdirect.com/manual/234cu4elin-001428/frigidaire-fphf2399mf2-bottom-mount-refrigerator .
I hope this helps.
Frigidaire... | Answered on Oct 18, 2019
If new and under warranty contact supplier. If you attempt to fix while under warranty and cause further faults then you may void warranty.
Frigidaire... | Answered on Oct 03, 2019
I would say that either the filter has split or the seal where it screws into the housing has failed. I would try a new filter and seal.
Frigidaire... | Answered on Sep 23, 2019
There are a number of reasons why this might be happening. You bets bet if to call a service guy out and let them take a look at it as some things require specialised equipment to troubleshoot.
Frigidaire... | Answered on Sep 14, 2019
Frigidaire FRT18S6J Top Freezer Refrigerator Logo
1 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire top
  • Refrigerators
