20 Most Recent
HEWLETT-PACKARD ProBook 4320s C Notebook Questions & Answers
Dear Sir
I have purchased HP
yes this model supports face recognition software, you must have software installed already, facial recognition software, click on windows logo (Start button) and go to all programs, and find Facial Recognition or similar.
Mouse is stuck on my
You
might have disabled the touchpad accidentally. If the touchpad is
disabled it is indicated by a yellow LED on upper left corner of the
touchpad and when the TouchPad is active, the light is off.
To turn the TouchPad on, quickly double-tap the TouchPad off indicator (the yellow LED).
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
I recently bought a HP
i've installed this program http://touchpad-blocker.com/download/
it worked fine for me.
I had issues with the touchpad clicking while i type. it was so **king annoying
Where can i download bluetooth driver ?
Hi, you can download it from HP.com search your laptop for example probook4320 click on it when it find your laptop choose driver download find bluetooth driver and hp wireless manager ,you can on or off the bluetooth driver with wireless manager software,or you can google it or you can use windows update service on the control panel to update your driver,and hp has a software call HP ADVISORuse it to update you driver in the maintenance tab kind regards
Network card wont connect
Step 1:wireless or hard wired ethernet connected ? The HP Mini has built-in Bluetooth capabilities that allow you to connect keyboards, mice and other Bluetooth-enabled accessories without using wires. Before you use the Bluetooth on an HP, you first need to enable it. Powering the Bluetooth on the computer on is easy to do, however, and should only take a few Click on the start menu from your computer's desktop. Select "All Programs" from the options on the Start menu. Choose "My Bluetooth Places" from the program menu. Choose "Power On" from the menu when it appears. Select "Search for new devices" from the menu to locate and connect your Bluetooth accessories to your Mini.
The touchpad stopped working with
If you have windows installed you can go to "Control Panel." Select the "Device Settings" tab and click "Enable" to enable the touchpad. Click "OK" to save the changes.
If that does not work. you can press the touchpad for 5 to 10 seconds.
