20 Most Recent HEWLETT-PACKARD HP TouchSmart 300-1125 Tablet Questions & Answers
Hp touchsmart 300-1125 will not boot, it gets to the logo screen and stops
1, Disconnect the power cord and switch off the computer. Tap and hold the power button for 5 seconds. 2, Switch on the computer and reconnect the power cord. Turn on the computer and tap the F10 key for about every 5 seconds. 3, Press the F5 key and this restores the default settings. Tap the Enter key for the changes. Press the F10 key for opening the Save and Exit window. 4, Tap the Enter key and this saves the changes and restarts the computer.
12/28/2018 6:17:08 AM • HEWLETT-PACKARD... • Answered on Dec 28, 2018
Itunes syncing problems
I met some similar problem too with itunes. But did you try other third party software to transfer your songs or photos? Maybe you can have a try. If so, look this: 3 Ways to Transfer Music from iPod to iTunes Library If the problem still exists, you may have to reinstall your computer OS.
11/26/2018 6:46:47 AM • HEWLETT-PACKARD... • Answered on Nov 26, 2018
2answers
Computer (HP Touchsmart 300) shuts down
Hi
By any chance does your power supply have an on/off rocker switch on the back? Is it on? I don't mean a red voltage adjustment switch, however. If that isn't it, do you have access to another power supply to install and test? As unlikely and coincidental as it might seem, perhaps the power supply is the problem and needs replacement.
Pull off the main 20/24 pin motherboard power connector then using a small wire or a paper clip connect the green wire with one of the black wires on the 20/24 pin plug, the psu should fire up and the drives will spin up, if not then the psu is dead. When you do this test there needs to be at least one hdd/odd connected to the psu since most psus have minimum load requirements to run. Some PSUs have a rocker switch on the back that cuts the power, be sure to check that out too.
Check this helpful link to test the PSU:-
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
3/25/2014 7:54:19 AM • HEWLETT-PACKARD... • Answered on Mar 25, 2014
2answers
I have the HP TouchSmart
Hi, This is the problem of either Virus or system files. So first install a total security Antivirus. Activate and update the antivirus. Then scan full computer and clean all viruses. then reboot the system. Restore the system at the previous date when the system worked fine. It will solve your problem. But remember make a copy of all recent documents and files before restoring the system. Because system restore can remove those files which you have create after the restoring date.
9/7/2011 2:13:00 AM • HEWLETT-PACKARD... • Answered on Sep 07, 2011
I have a HPtouchsmart 300
what browser are you using? try to use a different browser to access that turbotax site. you could try using Mozilla firefox or Chrome. this is more of a browser related problem than HP touchsmart. I hope that assists.
2/26/2011 9:21:24 AM • HEWLETT-PACKARD... • Answered on Feb 26, 2011
Why can't i see captured pictures on my touchpad?
1, First, open the Settings option and select Device Information. 2, Choose the More information button and then select Software on the top of the next screen. 3, Scroll down and select Photos and Videos. A pop-up window appears and select Done.
12/28/2018 6:13:57 AM • HEWLETT-PACKARD... • Answered on Dec 28, 2018
2answers
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM • Tablets &... • Answered 2 days ago
2answers
Naxa NID-1070 2-in-1 Core Android 11 Tablet. My mom doesn't remember password for screen how to unlock.
Question edited for clarity, add maker. Not a good idea posting your email address as a user name!! This site get 11 million viewers a year including thousands looking for addresses to harvest and spam. We don't email answers, it is all done on the site. You have to turn it off and then hold the buttons. https://www.google.com/search?q=naxa+Nid1070+tablet+reset ..
4/4/2024 7:44:14 PM • Tablets &... • Answered on Apr 04, 2024
Straight wire charger to jp5 tablet
It is a non-proprietary see through charger as seen here https://www.google.com/search?q=jp5+tablet+charger ..
3/31/2024 5:51:01 PM • Tablets &... • Answered on Mar 31, 2024
2answers
How to get iPad unlock when you forgot your password?
If a power cycle does not resolve your issue, you may need to perform a hard reset. To do so press and hold the Sleep/Wake button and Home button until the Apple logo will appear and iPad will reset. You can also perform a factory device reset.
Apple iPad 4th Gen (2020) - Reset Device - AT&T
How to Hard Reset or Restart an iPad (All Models)
Lifewire https://www.lifewire.com > Apple > iPad Oct 19, 2023 - For iPads without Home Buttons: Quickly press volume down, then quickly press volume up, then press and hold the on/off button. Skip to step 3. ..
3/23/2024 11:24:03 PM • Tablets &... • Answered on Mar 23, 2024
How do I start my ONN tablet please?
Press the On button on the ONN tablet :>D https://www.google.com/search?q=start+my+ONN+tablet ..
3/7/2024 8:27:51 PM • Tablets &... • Answered on Mar 07, 2024
ProScan Elite tablet/DVD Player. Why won't it connect to WiFi?
Sorry to say, but Proscan are cheap Chinese junk that costs $60. If your WiFi is STRONG, and you are close to it, just send it back. https://www.google.com/search?q=ProScan+Elite+tablet%2FDVD+Player You will see in this link that it is a known issue. https://www.google.com/search?q=ProScan+Elite+tablet+DVD+Player+won%27t+connect+to+WiFi ..
2/28/2024 5:17:16 AM • Tablets &... • Answered on Feb 28, 2024
Can't remember my password to unlock my JPay tablet?
Forgot Password
JPay http://www.jpay.com > ForgotPwd Please enter the email address associated with your JPay account. We'll send you an email with instruction on how to reset your password.
Have a jpay tablet and trying to unlock it. followed the
JustAnswer https://www.justanswer.com > Android Experts May 1, 2021 - Power off your Tablet. · Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ... · Choose ... 1 answer · Top answer: Hello and welcome to JustAnswer, I'm Tauseef, Technology Expert with JustAnswer and ...
I was recently released from prison and I'm trying to unlock
JustAnswer https://www.justanswer.com > Mac Problems Jul 6, 2021 - Please enter the email address associated with your JPay account. We'll send you an email with instructions on how to reset your password. https ... 1 answer · Top answer: Hello. Welcome to JustAnswer.com [//JustAnswer.com], an independent paid... ..
2/22/2024 4:57:08 AM • Tablets &... • Answered on Feb 22, 2024
Crystal View NB4-3/5788 7 inch Netbook. I forgot the password, no volume button. How factory reset with no volume button.
Question edited for clarity. You can't. You have to fix the Volume button first as it is the thing that initiates the reset. But you can try the volume Up button instead. Some version of Android will work with either or both Up and Down.
How do i hard reset my crystal view net book 7in NB4-3/ ...
Ask Me Fast https://www.askmefast.com > How_do_i_hard_reset_... If your tablet is on, power it off. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power).
How to reset my crystalview nb4-3/5788?
Ask Me Fast https://www.askmefast.com > How_to_reset_my_cryst... "Do the manual hard resetting for your crystalview xt netbook step..." · 1. Hold Power button + Home Button + Volume UP · 2. Hold Power button + Home Button · 3. https://www.google.com/search?q=Crystal+View+NB4-3%2F5788+hard+reset ..
2/11/2024 10:37:29 PM • Tablets &... • Answered on Feb 11, 2024
I recently got the iPad 15 Air, and I'm excited about its features. However, I'm curious to know if there are any hidden tips or tricks that users have discovered to enhance the overall experience..
Multitasking
take advantage of split screen multitasking to use two apps simultaneously. Swipe from the right edge of the screen to open the dock, then drag an app to the left or right side of the screen.
1/26/2024 3:38:27 PM • Tablets &... • Answered on Jan 26, 2024
HEWLETT-PACKARD HP TouchSmart 300-1125 Tablet Logo
14 questions posted
Top HEWLETT-PACKARD Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a HEWLETT-PACKARD Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Tablets & eReaders
Most Popular Question
hp touchsmart 300 1125 will not boot
  • Tablets & eReaders
