20 Most Recent
Storm Build Survival Shelter Bunker - Storms 2012 ?ez Cd Plan Questions & Answers
Is it safe to have electricity in underground
I would see why it shouldn't. As long as you install all connections properly and ground it out right. BUT I would not be hooking up my big screen tv to it. I would only use it for lighting and small thing as such. Just to get you by till you can exit.
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
No sound ..Floureon 4 channel NVR Camera system...Help
- Access Menu then go to Record. Choose Parameters then Record .
- Change the Camera to where your microphone is connected (e.g. channel 1).
- Change the Stream Type to Video and Audio.
- Put a check on the box beside Record Audio. If you cannot see it, click More Settings first.
- Click on Apply to save the settings.
