20 Most Recent Ibanez S5470 Prestige Electric Guitar Questions & Answers
Wiring a guitar
Here's the diagram.You should have all 4 wires from the humbucker pickups if you want the 2nd and 4th position to work.
9/27/2017 4:11:35 AM • Ibanez S5470... • Answered on Sep 27, 2017
I have a ibanez serial number f520866 can you tell me whot it is
Great guitar a real beautyfull solo guitar to ripp some awesome tunes
11/26/2014 1:44:30 AM • Ibanez S5470... • Answered on Nov 26, 2014
2answers
Had my guitar PLEK'd because
Take it in for setup. Likely the truss rod or the bridge is out of adjustment. Wrong strings can also cause the problem. There are YouTube videos on guitar setup... I would NOT attempt truss rod adjustment yourself.
2/2/2012 7:53:33 AM • Ibanez S5470... • Answered on Feb 02, 2012
My s5470 ibanez has a
Volume levels change depending on the settings... Also the harmonic content changes so the "apparent" volume will seem different. Find somebody else with the same unit and compare them side by side. Also the type of strings MAY change the sound.
9/6/2011 12:47:14 AM • Ibanez S5470... • Answered on Sep 06, 2011
0answers
2answers
My s5470 does not sustain
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
7/2/2011 11:52:51 PM • Ibanez S5470... • Answered on Jul 02, 2011
Hi, I bought an Ibanez guitar but don't really know much about it. Could you tell me by the serial number and what it's worth today ? It's an AR 300 series #S12091193.
it was one of the first original designs the company produced. this series has all the staples this brand is famous for fast necks, floating terms, and high octane distortion. it is worth about 350.00$.
6/15/2021 11:57:59 AM • Ibanez Music • Answered on Jun 15, 2021
Can i rewire my ibanez 06 sr305fm without the balance pot? if so how ? it has front and rear DX5 battery powered pickups.
Koinqq: Situs PokerQQ Domino99 BandarQ Online Terpercaya https://koinqq.top
12/7/2019 9:44:21 AM • Ibanez Music • Answered on Dec 07, 2019
Installed EMG 57/66 into and Ibanez PS 10-2. Plugged all wires as shown in the instructions. Had to install a longer stereo jack plug. Now I only get bridge pickup. Cannot get neck pickup to work.
It calls for a stereo input jack? I'm not sure but I think It is probably calling for a 1/4 unbalanced input jack , keeps your signal mono. so if you are only getting the bridge pickup. You might check your position switch. and or your lead pick up. simply take the designated wire from the lead pick up and hook it up where your bridge position pick up is connected. (disconnect that first) if you get sound, then it just may be your switch. if you get nothing? check to make sure you have your ground correct and he lead wire correct. If these are active pick ups? you''ll need a battery source. if stil get nothing. your pick up may be bad.Thats a reads digest troubleshooting explanation. check your basics first. good luck
8/26/2019 10:37:48 AM • Ibanez Music • Answered on Aug 26, 2019
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
8/26/2019 10:28:56 AM • Ibanez Music • Answered on Aug 26, 2019
2answers
Ibanez serial number
And what serial number is it?
5/16/2019 12:53:48 AM • Ibanez Music • Answered on May 16, 2019
What year was the ibanez jamboree Model 680 Serial No. 901961 made.
Ibanez guitars have used serial numbers since the mid 1970s. Some sources say the practice started in September 1975, but serial numbers indicating production as early as October 1974 have been spotted.
3/15/2019 1:27:54 AM • Ibanez Music • Answered on Mar 15, 2019
3answers
Finding this particular guitar and its value. The Ibanez 2670RE Artwood Twin is a double-necked electric guitar .
fixya doesnt do appraisals notify a music shop
7/17/2018 6:40:23 PM • Ibanez Music • Answered on Jul 17, 2018
I need a wiring diagram for a Ibanez Silver Cadet 4 string bass guitar
Know the year etc? Ibanez have them on-site. Ibanez com Wiring Diagrams
1/30/2018 10:14:50 PM • Ibanez Music • Answered on Jan 30, 2018
Y Does this Sound Like A Fluttering Or F@rting Ibanez WD7
The truss rod in the neck needs adjusting to rid the buzzing sound. I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
12/9/2017 3:33:57 AM • Ibanez Music • Answered on Dec 09, 2017
Ibanez S5470 Prestige Electric Guitar Logo
7 questions posted
Top Ibanez Music Experts
Ngoro
john h
Are you an Ibanez Music Expert? Answer questions, earn points and help others
View Most Popular
Ibanez Music
  • Ibanez Music
Most Popular Question
ibanez serial number f520866 tell me
  • Music
