20 Most Recent Mackie PPM608 / C300z PA Package Questions & Answers
From the way you have worded the question, I would say you're in no way certified to do this. Take it to a professional.
Mackie PPM608 /... | Answered on Oct 31, 2017
It is located on the Power Supply PCB next to the ac line voltage plug.
Mackie PPM608 /... | Answered on Oct 15, 2012
You use a VERY long phillips screwdriver as there are screws in those deep wells from the back. I think it takes a #3 phillips and you want one with at least a 12 inch shaft to reach the screws. The screws are black and are Kaylon or sheet metal types with pan heads. It can be a little tricky to engage the screwdriver bit as deep as these are.
Make sure ALL screws are completely out... count them vs the number of wells... there are a lot!
Then you have to pry the back off.
Mackie PPM608 /... | Answered on Mar 17, 2011
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
Mackie Music | Answered on Sep 27, 2019
Here you go
http://www.mackie.com/products/onyx4bus/pdf/Onyx_4Bus_OM.pdf
This link to the manual is on the Mackie website
Mackie Onyx 32 4
Mackie Music | Answered on Jun 08, 2019
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
Mackie Music | Answered on May 03, 2019
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16
I hope you can solve the problem you have with your Mackie
Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16
Espero que puedas resolver el problema que tengas con tu Mackie
https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
First thing to do is get a can of contact cleaner. Take off the knobs and spray it into the reostats below. Spray into all the switches and even into the sliders. Move everything back and forth - 0 to 10 (to clean them). If we're lucky, that will fix it.
Good Luck
Mackie Music | Answered on Dec 26, 2018
First, unless you are a trained or self-taught audio technician, don't attempt to repair the unit yourself. Let the professionals repair it. You can damage it beyond repair if you don't know what you're doing.
Non-working channels are caused either by bad connections, bad solder joints or a dead IC op-amp.
The causes of weak channels can be more challenging to track down. I'd suspect bad connections, dirty controls or connectors.
Mackie Music | Answered on Nov 06, 2018
Glenn, Does it say 'overvoltage', or simply 'voltage'? For the clearest result brother, contact Mackie - 1-800-898-3211 is their tech line - they're super cool - I just always picture the guys at Mackie sitting around reading comic books and shooting guns into the air. good luck!
Mackie Music | Answered on Sep 29, 2018
Mackie PPM608 / C300z PA Package Logo
7 questions posted
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
mackie ppm608 powered mixer
  • Music
