20 Most Recent
Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System Questions & Answers
What could be wrong?
Put it in MONO mode.
You can also make a cable where the TIP and RING are wired together....
I feel that the 'normal'
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
The ew 3000 iem (brand
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards,
Tony
How do I un mute the pack
It looks like the mute function is only available from the menu... not very user friendly at all... I guess they figure the performer doesn't need to mute easily or quickly... Volume control I suspect is all that is readily availab;le at the pack to quickly mute.
Disturtion in one left channel
Make sure you are NOT overloading (clipping) due to excess signal into the transmitter end of this unit. Reduce the gain INTO the fixed unit and see if the sound improves.
Some Headphones have an inherent
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
