20 Most Recent
Korg PS60 61 Portable Performance Synthesizer KEY ESSENTIALS BUNDLE Questions & Answers
How to perform a factory
1. Power-off the PS60.
2. While holding down the four PERFORMANCE
buttons and the OCTAVE DOWN button, power-
on the PS60.
The PS60 will be initialized, and the factory-set data
will be written into internal memory. The display
will indicate "Initializing..." while data is being
written. Never turn off the power while this
indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
My Korg PS60 sounds veey low with Headph
It is NOT normal... Apparently one side of the audio drive is bad, Take it in for WARRANTY repair immediately. Also read your manual in regards to "Panning" and any settings for it.
My ps60 has a high
Hello Brian, It could be a ground loop problem, I usually get something similar when connecting a laptop to an amplifier. You can purchase ground loop isolators from car hifi places which are used to take ground loop problems out of car audio systems. They are very cheap so maybe worth trying this first. I got one for £12. They have stereo RCA input/outputs and require no power.
Hopefully this is of help to you.
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
3/8/2022 8:37:05 PM •
Korg Music
Answered
on Mar 08, 2022
