20 Most Recent
Printronix Line Matrix P5005B Printer Questions & Answers
P5005B CFX firmware not found
The flash memory has probably been erased (assuming no one remove the memory module).
Your Printronix service technician can diagnose and reflash if needed.
Steve W
LazerTek LLC
HB not install see manwal
printer not detecting hammer bank . check all hammer bank cable or hammer bank interface circuit is faulty
My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Self text page
PRESS ONLINE IT COME OFFLINE
THEN FOLLOW STEPS
PREV<DIGONOSTIC<PRINT TEST<SHIFT RECYCLE<ENTRE
