20 Most Recent
Mackie cfx20 mkII compact mixer Questions & Answers
I can't get sound
Please post some more detail of how each channel is set up and what you have assigned where. My guess is that reading the manual may sort your issues.
I have an opportunity to buy a cfx20 mixer from a
If headphones have both sides working, it is NOT the main fader. It would most likey be the driver chip for the failed side that has been blown. This is common problem when people fail to power the mixer from the same receptacle or power conditioner that amps and other connected equipment are powered from. Ground bounce damages the circuits. The balanced outputs are driven by NJM4560 op amps which are likely surface mounted 8pin chips... .
Here is service manual:
http://elektrotanya.com/mackie_cfx20_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers.
Our mixture MACKIE CFX 20 give a humming sound as the clip light always on, but this does not happen before, tell me how to stop this
You say the clip light is always on, as the only clip lights on this mixer are on the effects channel and the master output and you do not say which is on there are a number of possibilities. You may have the effects turned up too far as this should not be showing, just maybe blinking, turn them down on efx2 on all strips as well as on the effects processor and see if this helps. If it does you may be able to find where the hum is coming from by gradually increasing each until you find it.
If you are getting the clip on the main mix master and you are not being deafened and the humming sound is coming from the speakers not the mixer you may have a subsonic signal getting into the mixer. Disconnect all inputs and if this cures it go through until you find where it is getting in and sort that.
If the humming is coming from the mixer it is possible that the smoothing caps on the PSU are dying, you do not say if you are getting normal sound as well as the humming from the mixer.
When asking for help please try to give as much information as possible
Would you know how to correctly open a CFX20 to
Yopu do NOT clean the pots... if you have noisy sliders, get some CRC226 at Home Depot in the electrical dept. Spray a small bit in the center of the slot for the slider and run the slider up and down. Use sparingly and apply a tiny amount once more. The sliders are NON_REPAIRABLE if this won't fix them and major disassembly is required involving removing the round knobs, fader knobs, screws and other nuts on the jacks. Hours of work. Pots require desoldering tool and use of soloder wick and plunger type removal tools often causes damage to the circuit board.
Occasionally at power up, all the channel signal
Make sure you are using balanced lines, especially to the power amps. ALSO make sure ALL interconnected equipment is powered from the SAME receptacle or source, even if it means running extension to where the amps are powered. Ground loops are a pain and can cause serious damage to your equipment.
