20 Most Recent M-Audio Studiophile DSM-1 Single Speaker Questions & Answers
I just had the same issue. The temporary fix I used worked for 2 years. I just stuck a small paper clip or safety pin in the corner of the port, and then plug the cable in. If those are too big just use something you can use to make the plug fit tight.
It finally stopped worked a couple of weeks ago, so I just bought a new USB port at an electronic store for $1.50 and soldered it on. I had to buy flux which was $3.00.
$5 and an hour of time after squeezing 2 extra years with paper clips. Priceless.
Just make sure you have a cold beer to solder with. Sticking drinks in a freezer wrapped in a wetpaper towel for 15 minutes is like a reverse microwave for beer.
M-Audio Music | Answered on Oct 09, 2017
Make sure only the midi input is set, not the output, and that the channel your using is armed. Otherwise the signal won't get through in record mode.
If your just using as a controller don't set the output. You only need to set the input.
Make sure the channel your using is armed as well. The button below mute & solo will be red if it is.
There are several reasons why this could be happening, assuming it's Windows, not MAC.
-Check to make sure the OUT port isn't set. You only need IN for basic controller use.
- Make sure the channel your using is armed (button below Solo & Mute should be red) [this is the most likely problem]
Another problem is the USB power settings in Windows. The default is set to allow the Computer to monitor and turn off USB ports automatically to save power. But it doesn't turn them back on automatically. You'll want change these settings regardless to help reduce latency issues.
-Go to Device Manager> USB Controllers> double click & change power settings to OFF for all Root Hubs.
Here is a guide to help optimize Windows to lessen Latency, Dropouts and Clicks /Pops. It's for Studio One, but the settings are the same for Windows.
You might want to give Studio One a try. I've used everything and by far Studio One is the easiest with the least issues. The free version is better than most DAWS paid versions. It can definitely help eliminate a lot of the everyday headaches that come with using Abelton, Cubase, Protools and even FruityLoops (which is pretty gay anyway).
M-Audio is also notorious for USB hardware related issues. A lot of times I find it turns out to be a bad connection between the plug and keyboard port, which tends to wear after awhile. It can go unnoticed because it still fits tight enough to get power, but not enough to keep the board fully functional.
Hope this helps.
I would suspect the sustain pedal jack on the keyboard is either dirty or defective. Try using some contact cleaner first, and if that doesn't work replace the jack.
M-Audio Music | Answered on Apr 29, 2016
What kind of a unit is it?
M-Audio Music | Answered on May 15, 2014
Power bottom has to be replaced,
M-Audio Music | Answered on Nov 04, 2012
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
Music | Answered 3 hours ago
Zager yes, but Salisbury Cathedral is a church in Hampshire UK
https://www.google.com/search?q=Is+Salisbury+Cathedral%2F+Zager+Guitars+legit
Music | Answered on Jan 16, 2020
go to www.reliable-store.com you will get it there
Music | Answered on Jan 09, 2020
I AM Making a Good Salary from Home $6580-$7065/week , which is amazing, under a year ago I was jobless in a horrible economy. I thank God every day I was blessed with these instructions and now it's my duty to pay it forward and share it with Everyone. go to home media tech tab for more detail r einforce your heart........... :*
???? COPY THIS WEBSITE ????
HERE?...............www.richfly2.com
Music | Answered on Jan 04, 2020
M-Audio Studiophile DSM-1 Single Speaker Logo
Popular Tags
0 questions posted
Top M-Audio Music Experts
Michial Gueffroy
PickyPrick
Poul Brinchs Larsen
Are you a M-Audio Music Expert? Answer questions, earn points and help others
View Most Popular
M-Audio Music
  • M-Audio Music
Most Popular Question
keyboard sustain now reversed polarity
  • Music
