20 Most Recent Behringer Xenyx 802 8-input 2-bus Mixer W/ British Eq ! Questions & Answers
Need help with mixing for kondensation microphone
For audio mixing on PA audio equipments a dynamic microphone will give almost the best results without noise or (singing) feedback from your speakers. Condenser microphones should better performing for recording of sounds because of the higher sensitivity that they have special for it.
12/18/2017 11:24:32 AM • Behringer Xenyx... • Answered on Dec 18, 2017
3answers
Latency during recording - makes playing in time impossible
I can totally relate, Tom. Good old multitrack recorders! This may sound stupid, but you don't have like a slap back delay turned on by mistake, do you? Other than that, I'm afraid I'm not much help.
2/16/2015 6:11:22 PM • Behringer Xenyx... • Answered on Feb 16, 2015
0answers
2answers
I am getting minimal to almost no sound coming from my mic to my computer.
If you are using the fx/send port to the mic-in port (I have no idea why you would want to do that) but nevertheless, check the red fx dial and make sure it is at 12 oclock and turn the pan dial to 12 oclock also. remember if you are using mic input 1 or 2 with a mic that requires Phantom power the button needs to be locked in the down position. OK im assuming you have checked and set your gain and volume levels on the 802 prior to plugging in your mic. If not do so now.(unplug all outputs and with mic plugged in speak into the mic while turning up gain until you get distortion which is indicated by a rewd light next to the "pan" button...once you see that light turn the gain dial back slightly and you should be set) have volume at 12 oclock on both l"evel1" and "main mix: dials. Now goto your windows desktop and right click on your volume control "speaker" icon. Click on "Playback device" you should see your mic in the list on enabled devices.If you dont see your mic in list right click the screen and click show disabled devices. Enable your device. If it is already enabled right click it and make sure it is not muted. finally go back to list of playback devices and right click your mic and click "configure speakers" run through the tests. close everything.mic should be working now. If it is not I suggest you plug your mic into either the line in from the fx/send or keep it in the mic-in port and plug the other end into the head phones port.Or better yet, get an rca to mini stereo jack and use the cd/tape out jacks to send your signal to the mic port of your computer......keep playing with it...you'll figure it out.There are so many different ways to hook up your perephrials its mind numbing sometimes.
3/27/2013 9:55:53 AM • Behringer Xenyx... • Answered on Mar 27, 2013
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
1/15/2013 12:14:48 AM • Behringer Xenyx... • Answered on Jan 15, 2013
I'm looking to run 5
You could use the Left inout of one of the stereo channels. You can pan it with the balance control as needed... HOWEVER remember these are LINE LEVEL signal levels into the stereo jacks... so if you are using instruments with low output you MIGHT have to use a preamp to go into these jacks. Try it... nothing ventured, nothing gained. Using a keyboard into these jacks would NOT be a problem.
9/2/2011 6:13:48 AM • Behringer Xenyx... • Answered on Sep 02, 2011
Hi all i own a behringer
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
3/29/2011 10:04:08 PM • Behringer Xenyx... • Answered on Mar 29, 2011
How can i setup mu xenyx 802 with my pc? i also
You can do it one of two ways when coupled with the FCA202. First, You can just come out of the main outs on the 802 via 1/4 in to the 202s 1/L in and 2/R in. Second, you could do two separate channels (ie. Vocal channel and Guitar Channel) using the L/R out on the 802. Use the pan knob to send the instrument to the selected channel. So, If your Guitar is on channel 1 pan hard left and you will only get it out of the left channel sending to channel 1 of the 202, and your vocal is in channel 2 pan hard right and you will only get it out of the left channel sending to channel 2 on the 202. Good Luck, Cody J.
12/17/2010 8:44:34 PM • Behringer Xenyx... • Answered on Dec 17, 2010
Is there a reset button on my 802?
I do not remember if the powersupply is external or not either way there is no reset button the powersupply may not be putting out any voltage.
12/1/2010 8:12:10 PM • Behringer Xenyx... • Answered on Dec 01, 2010
I have a Behringer PMP2000D Europower 800-Watt 14-Channel Powered Mixer & I'm getting no sound out of channels 1-6 but I'm getting a signal just no sound & fuses are fine
You will need an oscilloscope and a good grounding in electronic servicing to attempt a repair. But, check the signal routing. Refer to the user manual.
1/18/2024 7:34:56 AM • Behringer Music • Answered on Jan 18, 2024
I have a Behringer Xenyx 1204FX and the DSP Display doesn't illuminate (but works by pressing down and turning the knob). Any idea why it's not on? Also the AUX 1 Send doesn't seem to be working
It sounds like you're experiencing a couple of issues with your Behringer Xenyx 1204FX mixer. Let's address each of these problems separately:
  1. DSP Display Not Illuminating: The fact that the DSP display works when you press down and turn the knob suggests that the issue might be related to the display itself or its connection. Here are a few steps you can take to troubleshoot the problem:
    • Check Power Source: Ensure that the mixer is receiving proper power and is turned on. Sometimes display issues can be caused by power-related problems.
    • Connection: Make sure the ribbon cable or connector that connects the display to the circuit board is properly seated. A loose connection could be causing the display to not illuminate.
    • Faulty Display: If none of the above steps work, there might be a problem with the display itself. You may need to contact Behringer support or a professional technician to get the display repaired or replaced.
  2. AUX 1 Send Not Working: If the AUX 1 send is not working as expected, there could be several reasons for this:
    • Routing Settings: Make sure that the AUX 1 send is properly routed to the desired destination. Check the routing options on the mixer to ensure that the signal is being sent to the correct output or destination.
    • Level Controls: Verify that the level controls for AUX 1 are set correctly. Make sure that the AUX 1 knob for the specific channel you're working with is turned up.
    • Effects/Processing: If you're trying to send a signal with effects applied, check if the effects are set up correctly. Sometimes, an incorrect effect or routing setting can affect the AUX send.
    • Cable and Connections: Ensure that the cables connecting the AUX 1 send to external devices (such as monitors or effects units) are functioning properly and securely connected.
    • AUX Master Level: Confirm that the AUX 1 master level (usually located on the main output section of the mixer) is turned up to an appropriate level.
If you've gone through these troubleshooting steps and the issues still persist, it might be a good idea to consult the user manual for your Behringer Xenyx 1204FX mixer for further guidance. If the problems continue, you may need to reach out to Behringer support or consider seeking assistance from a professional audio technician or repair service.
8/6/2023 8:22:16 AM • Behringer Music • Answered on Aug 06, 2023
2answers
Behringer Europower PMP 1680S--The FX channels both Master and Monitor banks do not create any effects but instead only produce a rapid, repetitive clicking/popping noise. HELP!
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects I hope you can solve the problem, comment the results Greetings Franco Dosil Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos Espero puedas solucionar el problema, comenta los resultados Saludos Franco Dosil https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdf https://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
7/29/2023 2:29:41 AM • Behringer Music • Answered on Jul 29, 2023
2answers
Behringer truth 2031a popping and sizziling stoppeed working, what to check first.
Check all the wiring connections on the speaker. Check the plug in points for the cables are not loose in the body of the speaker or the connector plugs themselves are not loose in the actual plug sockets. Next you will need to get inside the speaker body to check the connections and soldered joints. Take a good look at the back of the cable plug sockets and to the back of the actual speaker cone connections. Check each wire at Both ends for damage. No sound at all suggests the issue might be at the 'Input' where the cable plugs into the back of the speaker body.
7/18/2023 3:07:48 PM • Behringer Music • Answered on Jul 18, 2023
Behringer Europower pmp1680s Head/mixer rapidly powers up and down continuously
Sounds like a capacitor is bad.
6/26/2023 1:13:56 AM • Behringer Music • Answered on Jun 26, 2023
Behringer Xenyx 802 8-input 2-bus Mixer W/ British Eq ! Logo
16 questions posted
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
am getting minimal almost no sound
  • Music
