20 Most Recent Korg X50 X-50 Keyboard Questions & Answers
Factory reset on korg x 50
FACTORY RESET:
  1. Press the [GLOBAL] button to enter Global mode.
  2. Press the [EXIT] button.
  3. Press the [UTILITY] button
  4. Select "Load Preload Data," by using the ClickPoint [?] button, and press the [CENTER].
  5. Choose "Kind," (All)
  6. Press the [MENU/OK] button.
  7. When a dialog box will ask you, press the [MENU/OK] button
6/9/2016 2:50:51 AM • Korg X50 X-50... • Answered on Jun 09, 2016
GM VOICE NOT PLAYING
Your best bet is to contact Korg. Here is their link- http://www.korg.com/us/support/contact
1/22/2016 6:51:56 AM • Korg X50 X-50... • Answered on Jan 22, 2016
Korg x50 starting system hang
5VDC is absent. The 0 Ohm safe resistor is dead. Backlight is off in this case too.
10/23/2015 6:14:36 PM • Korg X50 X-50... • Answered on Oct 23, 2015
Please guys badly need yourhelp,have korgx50 problem is the tuning suddenly transpose up and down,and almost 50% of the program effects are not working properly maybe the IC is not functioning thinkso
I had an old organ/keyboard repair man tell me 95% of his repairs were diodes over 10 years old. Everything else was switches, capacitors & transformers. Hope that helps.
8/25/2015 3:54:52 PM • Korg X50 X-50... • Answered on Aug 25, 2015
I need a fuse for a Korg N364 keyboard.
No one knows the fuse type, but the details should be on the fuse itself. Then you can't get them from an electronics store or Amazon. The Service Manual is in the link. https://www.google.com/search?q=Korg+n364+keyboard+replacement+fuse ..
4/12/2024 4:58:31 AM • Korg Music • Answered on Apr 12, 2024
Korg D3200 asks for start up disc. Will not boot.
If you contact Korg, they can send you a dowloadable link to burn the software to a disc.
11/21/2023 9:36:55 PM • Korg Music • Answered on Nov 21, 2023
Hello. I am in possession of Ix300 Korg music workstation that is not able to boot up properly. Any chance of repairing?
up to you if you ant to spend the money to have it diagnosed and repaired
11/3/2023 2:31:49 AM • Korg Music • Answered on Nov 03, 2023
Loading system failed Korg m50
9/6/2023 8:00:59 AM • Korg Music • Answered on Sep 06, 2023
2answers
Korg X50. When switched on, why does it indicate: 'Waiting for the data from USB'?
Sounds like loss of memory\programming.Go to Korg website for download.
12/30/2022 3:04:37 AM • Korg Music • Answered on Dec 30, 2022
How to reset the korg radias to factory settings
7/23/2022 8:23:24 AM • Korg Music • Answered on Jul 23, 2022
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard. I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings. http://www.midiox.com/ Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced. Hope this helps.
3/8/2022 8:37:05 PM • Korg Music • Answered on Mar 08, 2022
Korg X50 X-50 Keyboard Logo
8 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
gm voice not playing
  • Music
