20 Most Recent
ASUS X5DIJ Notebook Questions & Answers
My Assus laptop has been
you mean black screen dead screen, 100% dead. no Asus splash.
the big battery is EOL DOA dead. we replace them but first
run the PC on AC powerpack first , no huge battery there.
work now? sure.
if not do the long power reset, push power button for 10 full seconds an release.
2009 PC birth day the coin is 8 years old , EOL spec on coin is 5-7 year. so we test it below 2.9vdc bad or replace it , if bad it can not be ignored.
no charger on earth can charge a bad battery , weak only not bad.
and is the first to fail , batteries all, then hdd 2nd
that is how it works, transistors can go 100 years, or more.
caps less. , 20 years is part
but not batteries, ask Elon Musk this, he knows .
or read at battery university dot com.
Asus laptop cannot connect to wireless network, any ideas?
If the only thing that has changed is the install of the AT0100 utility then I would un-install that utility. I'd agree that the wireless connection is sortof not the problem. The fact that can and are connected indicates that connection is being made. However, it could be an "ip" issue. If you are connecting through DHCP then your system should be able to pick up a new "ip" lease and it should connect though that could take just a little bit of time. You might go into the adapter settings and check your ipv4 settings and verify that it is selected for DHCP or an address with a correct subnet mask and Default gateway. A way to check is from the start button, type cmd and press enter. This will bring up a separate screen. At the Dos prompt type "ipconfig /all" This will give you the details of all network devices on your laptop and how they are trying to talk.
How i can fix my upside down cam
Goto Device Manager, select Imaging devices and select your USB Webcam. Right click and select Properties
In box that opens up select Details Tab.
In drop down menu for Device description, choose Hardware Ids
Now write down details of it beginning with USB\VID and search for that driver and install it after uninstalling the previous version.
