20 Most Recent
Dell 3200MP Multimedia Projector Questions & Answers
Dell 3200mp
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @
[email protected] and let me know. Good luck thx sean
Dell 3200MP DLP Projector: displays OK, but with
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Pictue shakes
Sounds like the lamp needs to be replaced. Does the "lamp" light on the top turn solid orange when it turns itself off? That's an indication that the unit has sensed that the lamp is no longer "good".
My dell 3200 mp projector
HI Wolfman,
You need to make sure that the input is correct because there are probabilities that you have it on component.
Thus you need to change it to computer which is RGB (red,green,blue) and then it should work fine.
Let me know if the problem persists.
Hope that helps...:)
Suddenly there is no power
1) Replace the power cable or verify that it is working.
2) Verify that the mains supply you are using is working.
3) Check the fuse, if there is one on the body of the projector in a user-servicable location. This would either be a barrel type holder which needs to be unscrewed or a pop-out cartridge type. It will be in the vicinity of the mains inlet. Ensure that the projector is disconnected from the mains before looking for the fuse.
4) If these steps fail to help your projector requires professional repair.
