20 Most Recent
Nakamichi CD-35z CD Changer Questions & Answers
Nakamichi cd 35z
Purchase a new battery I think there's something wrong with it. Did you check the battery's output with a multimeter?
I have a pioneer super
if you have an amp hooked up they may use the radio wire to the amp to sync your whatever your deck is hooked up to with your cd deck
Pioneer super tuner 3
Go to Pioneer's website and look up your model number.
Yes, you need your model number.
You should be able to find a user's manual there.
Knowing newer Pioneer's, with the power off, press and hold the function button until a menu comes up, then press to advance to clock settings.
Our Nakamichi CD player has
The CD player muigt be able to rescue by a reset top factory settings, mostly available in your manual, the cassette deck i think needs to be repaired.
Nakamichi cd-35z
There is adjustment for bass, mid and treble. Access this by pressing the button to the right of the volume knob. I leave mine set at +1/2, -3, +2 . I also set LOUD on which is done by holding the same button down.
With these settings everything sounds pretty spot on, occasionally need to adjust the bass up/down and treble dependant upon the CD.
