20 Most Recent
Pride Gl 358L Electric Lift Chair Riser Recliner: Floor Sample Questions & Answers
Lift chair does not work
Contact dealer first. If no dealer, then contact "Pride Service Center." Should be listed on your receipt.
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual.
https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
The latch won't stay latched on pride jet 3 ultra
If the latch on your Pride Jet 3 Ultra power wheelchair won't stay latched, there are a few potential causes and solutions you can try:
- Check for obstructions: Inspect the latch mechanism and the surrounding area for any obstructions or debris that may be preventing it from latching properly. Remove any obstacles and ensure that the latch can move freely.
- Adjust the latch position: Sometimes, the latch may need to be adjusted to ensure a proper fit. Check if there are any adjustable components on the latch mechanism and try repositioning them to achieve a secure latch.
- Tighten or replace the latch: If the latch is loose or worn out, it may not hold securely. Check if there are any screws or fasteners that can be tightened to secure the latch. If tightening doesn't solve the issue, you may need to replace the latch with a new one.
- Seek professional assistance: If the latch continues to have issues or you are unsure about making adjustments or replacements yourself, it's best to contact Pride Mobility or a certified technician for further assistance. They will have the expertise to diagnose the problem and provide the appropriate solution.
Pride GoGo mobility scooter cuts off.
Get a can of Electrical Contact Cleaner spray and separate any electrical connectors that you can see, and re-make the connection. You have a bad connection somewhere that is losing contact with a bump. The most likely places are any from the battery, or any to the controller. Make sure the two connector halves are fully locked in place. Some have fuses, some have breakers, check the connections there as well.
You say it has only done 8 miles. If you bought it new, it is under dealer and maker warranty.
I was hoping to find you a manual, but 'GoGo' is a range of models.
https://www.google.com/search?q=Pride+GoGo+manual
Shutting off on bumps is a known issue caused by the battery box bumping.
https://www.google.com/search?q=Pride+GoGo+shuts+off+on+a+bump
