20 Most Recent
LG LDA511 DVD Player Questions & Answers
LG RH278 DVD recorder has no power after power outage
The power supply regulator board should be troubleshooted. It will be best to replace this board as card basis, rather than making surgery to it. You can bought this board fro the authorised service center for LG at your town.
I have a 2005 LG
the problem seems like there is partial contact which is failing and letting the player turn itself on and off.
First, check the plug of your DVD player, it is possible that it is failing or loosing contact.
Secondly, get a screw driver, open the player's cover, check the power board and see if the power cord is partially connected to the board or not.
Good luck.
Lda 511 will not load disc
I used an o-ring to fix the problem. Quite easy to disassemble, old belt was removed and similar size o-ring was found at a hardware shop. Put the o-ring on the pulleys and viola. 68 cent fix
Front load DVD player will not accept the disk.
Invest in a new DVD player...it will be much simpler, will cost roughly the same amount AND save you the hassle of finding someone to repair the broken drive gear (cog) on the insertion/eject roller (if all else is known to be working). You will find it on the left side of the DVD bay connected to a tiny white worm gear and even smaller reduction gear. If you are handy with a precision hobby mill, you can easily turn a replacement gear out in relatively short order with only the tedious tasks of disassembly and reassembly of the shaft end to deal with. Be certain to unplug and discharge the capacitors in the machine before messing about the inside of the player (UNplug player and press the I/O, "on button," twice). One sturdy knife blade, one standard philips head and one small philips head screwdriver will be all you need for disassembly. If you are capable of opening the chasis and the DVD housing, you will be capable of removing the speed nut from the shaft of the insertion/eject roller and of deciding from there what you should do. Good luck.
DVD Locks up
Sounds initially like your loading mechanism needs service.
Are your discs clean and free of debris? Have your tried a disc cleaner.
Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Disc removal
