20 Most Recent
LG DVP7772 Portable DVD Player with Screen Questions & Answers
Portable dvd play and kid
The main board has been damaged, the water gets into the parts and causes corrosion and oxidizes turning any ic a green color. To attempt a repair the player will need to be unplugged and the battery removed before you dis-assemble the player. When you can see the boards, get some rubbing alcohol and a stiff toothbrush, dip toothbrush in the alcohol and scrub each part carefully removing any green on the boards and parts. After you finish let it dry overnight, and inspect the boards to see if any traces remain. If everything checks, assemble it back together and try the player.
It was working fine when i bought it,but now
Hi this is abhishek and welcome to fixya,,,,,,,,,
it normally caused by lens getting dirt,,,,first clean the lens with
soft cloth then try inserting disc i think the problem will be
solved....
thank u.......
Screen is tinted blue
show it your nearest authorised personnal, because its just some loose contact between the LCD pannel and the circuit board. Furtherly can be solved by seeing the physical condition of the set.
