20 Most Recent
LG MU-42PZ90V 42 in. Plasma Television Questions & Answers
Powers up with no Picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dvi to hdmi
You'll just need a DVI to HDMI conveter adapter you can find them at most electronics stores or online they may be hard to find but I have heard of people finding them and using them!
Why there is no backlight?
Plasma TV does not use backlight circuits or backlight inverter board. The screen is lit up by PLASMA EFFECT.
You are not getting anything on the screen?
I have a LG MU-42PZ90V
Hi:
On this model you must replace the power supply if the blown fuse was on the power supply, but the main cause for LG failure is the Y_Substain Board assembly. When measureing the voltage of the Large Capacitors, this is the primary side to the main supply, you must measure the caps form hot ground, on the AC side of the Standby transformer for correct Voltage, 66V is to low. Look at the side of the Lrg Capacitors for their voltage ratings, the Supply voltage to these should be some what near this voltage but never higher. The Y_Substain board is to the left of the power supply standing in back of the unit. Its possible its just the Y_Board gone bad, but in my experience the you should replace them both.
Ok, so i've established my
Video output of dvd player will be hooked in TV and audio/ sound wires of dvd player will go to sound system./ receiver input, this sound system/ receiver will amplify dvd player sound and drive its speakers.
Let me know any further question.
Thanks.
My plasma has no sound.
Ok I was looking online at your model television and there are no specifications for speakers. They keep calling it a monitor and usually the monitors do not have built-in speakers and require an additional sound system. Look around the unit and in the back and see if you see any signs of speakers. If there are small holes for the sound to come out from. Now if it does have speakers it is possible that it could be muted or the speakers are turned off in the menu settings for the television. I would buy a universal remote that is programmable for your television. If there are no speakers or you cannot get them working there should be audio out rca jacks that you could hook to a sound system. And then whatever input your telivision is set to the sound for that component will goto your sound system. My friend has a Sony ED plasma telivision(when plasma tvs first came out) and it does not have any built-in speakers.
My tv was given to
The TV may not have internal speakers. Try connecting the TV to a stereo or some external speakers
Just recieved a lg mu-42pz90v plasma t.v. We got
If your tv came with a remote, make sure sound is not turned to Mute.
Also try to press the DASP button repeatedly to select the appropriate sound setup to "Flat", "Music", "Movie", "Sports" or "User".
You can also do this from the Sound Menu.
Press MENU button and use up and down arrows to select SOUND.
Then press the left [>] button and use up and down button to select desired sound option. Press again left [>] button and up and down buttons to make appropriate adjustments. Press Enter to save.
Make sure cables for audio is also properly plugged to the right port.
