20 Most Recent
LG DU-42LZ30 42 in. LCD HDTV Questions & Answers
Hdmi cable cables
Have you looked at your tv for HDMI inputs? What do you want to connect to it? There are two kinds of Hi def cables, one has five rca cables ...3 for video and 2 for audio. The other is for a standard HDMI cable. Your tv should have one or both types of inputs. Converting to HDMI cables will not solve anything, because even some HDMI sources do not embed audio on the cable. Converters that do embed cost several hundreds of dollars, but you must have compliant TV's and devices you wish to connect to be sure they will work..
Hidden or Service menu
thank of you but i need access to menu service please help me
please mail key to access to menu service
thanks of you
No picture or sound
The symptom you describe points to a failed main power supply, unfortunately pretty common.
There may be an internal fuse you can replace but I wouldn't bother doing that more than once.
The clicking you hear is a relay that repeatedly connects,
then disconnects the AC to prevent fire or further damage.
If it just fails to turn on, the main power supply is probably at
fault and without some technical background and a couple of test instruments,
you will not be able to do the repair yourself.
What
you can do though is; unplug the set, let it stand overnight or at least
several hours, remove the back panel and look for a separate board with mostly
larger components on it; it will have a ferrite core transformer on it and
several larger capacitors which are cylindrical and mounted vertically to the
board.
Before touching anything inside, especially on that board,
allow several hours to be safe since the larger capacitors can hold a painful
voltage charge for some hours.
If you see signs of overheating such as discoloration of
the board material, it may not be repairable but if you can find a part number
on the board, you might be able to buy the power supply and install it
yourself.
If there are no signs of heat damage to the board, there
may be companies offering to repair it as a subassembly instead of repairing
the whole set which could be much more expensive.
If
you choose to replace or have it done, the power supply still may not be at fault since most
are capable of switching on and off if a downstream problem is causing an
overload.
Remote for dec pf2999st tv
Remotes.com may have an original remote or an acceptable substitute but using the model number you gave in the subject line, dec pf2999st, is somehow defective as it did not bring up any replacements.
Remotes
LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set.
Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have.
Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio
White - left channel audio
Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Picture but no sound
probably the internal amplifier for the audio output, get ureself an amp with some speakers and forget about the problem
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
