20 Most Recent LG RU-42PZ90 42 in. Plasma Television Questions & Answers
What is the issue or problem and it is LG?
LG RU-42PZ90 42... | Answered on Mar 23, 2012
I don't have a solution but I do have the same unit with vertical lines on the screen. I just had a tv guy come and diagnose my issue and he recommended I part it out on ebay. I'm interested first in trying to fix myself. Are you interested in selling me some of your parts?
LG RU-42PZ90 42... | Answered on Aug 18, 2008
Usually in most cases closed captioning will not work in S-Video mode because they are seperating the luminance (brightness) from the chrominance (color) hence the name S-Video (seperated video). Closed caption only works on composite video (yellow input) or antenna mode.
LG RU-42PZ90 42... | Answered on Jul 09, 2007
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent..
LG Televison &... | Answered 3 days ago
LG TV Codes 0178, 1265, 0039, 0037, 0606
1. Turn on a your device. NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control, press the TV key once.
3. Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
https://voxxintl.zendesk.com/hc/en-us/articles/225305947-Information-Owner-s-Manual-Code-List-and-Support-for-the-One-For-All-URC4220-Universal-Remote-Control
Without a remote control, you can't unlock it.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. https://remotesearch.blogspot.com/
https://electrohelponline.blogspot,com/
Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
it's a television not a browser!
If it is a smart television, Google
make model manual
LG Televison &... | Answered on Nov 10, 2019
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
LG Televison &... | Answered on Nov 08, 2019
I did not have my remote that went with our LG tv so I go to the side panel of the tv and touched the menu button, then options, then turned off the Simplink.
LG Televison &... | Answered on Nov 07, 2019
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
LG Televison &... | Answered on Nov 05, 2019
As far as I can see on the support page, here: Product Support
there is no firmware upgrade. An upgrade is only made, when several people have a issue with there device, and it can be solved by upgrading the firmware. Ir is NO SOLUTION for real defects.
You even can't upgrade if the device is not working correct.
It needs to run a short program, put is a small part of the RAM, and during the upgrade it can't lose power, because the little program has to flash (put new software in) the electrical erasable memory.
When something goes wrong during the update, nothing works and you need to visit a service centre to put things right.
As long as your TV works fine, don't update. When LG really does have an update, they will email all registered owners and carefully explain how to do the upgrade.
To be sure about any updates, register your TV on the support site.
When you have a problem with the TV contact LG or a certified repair centre close to you.
It would not be wise to try to change something on your TV, as long as you are not 100% sure it would improve the TV.
LG Televison &... | Answered on Nov 04, 2019
Did you try replacing the batteries, they go dead, especially if someone puts something heavy on it and it keeps a button pressed for a long time. I have an LG TV, and I did that, I now keep the remote on top of everything, never under things. If replacing batteries does not work, there are universal remotes that can be programmed to work to work with your TV, try a local store like Walmart and read the labels to make sure they list LG as one of the TV's the remote will work with.
LG Televison &... | Answered on Nov 02, 2019
LG RU-42PZ90 42 in. Plasma Television Logo
4 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg ru 42pz90 42
  • Televison & Video
