20 Most Recent
LG RU-42PZ61 42 in. HD-Ready Plasma Television Questions & Answers
I have a blue line
Hello:
Try replacing the T_Con board first. if this does not solve check the capacitors on the power supply for puffy tops, if you find some replace them with same voltage rating and Capacitance.
Sparkling on LG flatpanel tv
ok, phoned a technician today and he has diagnosed the y/suss board as gone and 150 to fix but cant guarantee it will fix it for good, another board may go pop z/suss . so its the local refuse collection point for it.
Same problem with my RX-42PX11
I have the same issue with my RU42PZ61, and I think it's the power supply board, but I'll take it to my repair man. He diagnoses it for $25.00, and tells me what part I need.
Colors
Problems with the digital video processing board. Need replace it.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
