Thank you for your inquiry, Herb!
I see that your Frigidaire refrigerator, FGHB2866PF, is not making enough ice. When is the last time you changed your filter? It is recommended to change your filter every six to nine months. If the filter is dirty the icemaker will not produce. You may also have a frozen water line and you can perform a manual defrost in order to clear out the line. To manually defrost your line you would need to disconnect power from it for at least three to four hours. If that does not correct your issue you may need to have a professional technician out to perform a diagnosis and repair. I hope this information is helpful. -Matt
I appreciate your inquiry, Tammy McAninch!
Based off the information you have provided your Frigidaire freezer door pops open when you open your refrigerator door. This can happen with new refrigerators because the seal is new. I understand your question is labeled under model FGHB2866PF. It could be issues with your door not aligned properly and hitting your freezer door to open. I would check the gasket to make sure they are creating the proper seal on your freezer in order to check that you can use a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you continue to experience issues with your freezer door I would recommend reaching out to a professional for further assistance. I hope this information helps to some degree. -Matt
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
6 questions posted
322 Questions
159 Questions
143 Questions
42 Questions
