20 Most Recent
LG MZ-42PZ14 42 in. Plasma Television Questions & Answers
My plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel
on the power board
it adjust the gas flow to the screen
is should light up your screen
Red Spots on 42" LG plasma t.v.
The dancing spots can be sorted by you taking the back panel off and adjusting the va and vs adjusting nobs , you will need a multimeter so you you can adjust the voltage to the right settings that are on a sticker on the back of the panel. You must remember to connect the black pointer to the earthed wire to get and the red to the live wire that has va or vs at the end of it. The right voltage measurements will be be found on a sticker at the back of the panel.
I advise you not to touch the setup and setdn nobs as these are factory settings and should not be touched.
If the va and vs do not sought the problem then try the vy and vsc adjusting nobs but only touch those if the va and vs does not fix your problem first.
Once you have done everything right your tv should be better then before with clearer pictures.
I hope this helps and be careful not to get zapped.
What leads to we need to connect a free-view box
in the uk i just used a normal audio av cable the one with a red a yellow and a white conectors on one end and a scart on the other end i have it this way 10 years now with no problems u can also use the s video lead to
Hello
I received a lg
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Monitor keeps going green lead
Try unplugging the lead at both ends and back in.
If this does not work get a new lead and try that.
There is a possibility that the connector on it is faulty but a new lead is a quick way to find out.
New 42 inch LG LED/LCD has lots of white and
0) make sure the tv has not been on for a while so that the lamp has time to cool. 30 minutes is probably adequate.
1) unplug tv
2) remove lamp cover
3) remove rear exhaust cover (if your tv has one)
4) carefully and gently remove all visible dust and dirt, especially from the fans. (I used a vaccum with a brush attachment)
5) remove the lamp according to your tv's instructions. Do not touch the bulb itself. Only handle the housing.
6) clean out any more visible dust and dirt where the lamp was
7) re-insert the lamp
8) tape the lamp cover safety switch so that it is always depressed.
9) plug the tv in
10)
Turn the tv on BUT DO NOT LOOK AT THE LAMP. Just verify that the fans
are spinning. If a fan is not working, you should look into replacing it
as the first step.
11) If the fans are spinning, put the rear exhaust cover back on.
12)
You can remove the tape from the lamp cover safety switch if you want,
but I left it on since I think it was causing my tv to randomly
shutdown. My tv has not shut itself down since taping the switch down.
Put the lamp cover back on.
13) Make sure the rear exhaust is not obstructed. I personally try to keep the rear of my tv at least 1 ft away from the wall.
