20 Most Recent Britannia SIE9TLS Electric Kitchen Range Questions & Answers
How can I change a faulty interior light
Remove the glass cover it it has one. Usually the cover is held in place by a metal spring bar going across the front.
3/10/2015 3:00:02 AM • Britannia... • Answered on Mar 10, 2015
Can I change the grill element in my britannia
I thought theses were removed from the top after removing screws or clips that attach the unit to surrounding surfaces.Could be wrong. But they are usually simple enough for the home owner to remove.
10/20/2013 2:56:59 AM • Britannia... • Answered on Oct 20, 2013
Oven does not switch off at set temperature. New
The pins from the element were very close to the back panel when fitted. This causes the nuetral to go to earth and bypass the thermostat. Bend the pins 90 degrees and the problem is fixed.
10/18/2009 8:32:31 AM • Britannia... • Answered on Oct 18, 2009
HMS Britannia light does not light?
1/4/2024 2:11:18 PM • Britannia... • Answered on Jan 04, 2024
My Britannia K20L7-100 extractor hood fan stopped working. The 3 speed switch only creates varying humming sounds from the motor? The motor armature has been thoroughly cleaned but still the same?
5 Common Kitchen Exhaust Fan Problems
You don't often realize how important your kitchen exhaust is until it breaks down. It gets rid of smoke, moist air, and food odors. Luckily, these five common problems are easy to fix. 1. Motor If the motor of the kitchen exhaust fan suddenly begins to make an unusual noise, it may be due to the fact that the motor is struggling to keep the fan running. When it gets to this stage, it is likely to be only a matter of time before the motor burns out completely. In this case, replacing the motor is the best option. If you have retained the instruction manual, keep this on hand during the removal process to help you to identify relevant components. Switch off the power supply and remove the cover of the fan to access its wires. Carefully unhook them before removing the other fasteners that hold the motor to the support and reverse the steps with the new motor. Ensure that the new part is made by the same manufacturer as the fan and is the correct model. Then check the manual to determine whether it outlines any recommendations as to suppliers. 2. Rattle A kitchen exhaust fan that rattles when it is in operation is likely to have loose or defective components that will have to be rectified. After switching off the power supply, check the fasteners holding the cover in place. If they are correctly secured, unscrew them in order to remove the cover and check for any loose parts. Repair or replace any components that you find to be faulty and make sure the screws are properly tightened when you replace them. 3. Power Failure If the exhaust fan fails to work at all when you switch it on, there are a few possible causes. Check whether the appliance has tripped the circuit breaker and switch it back into place if this has occurred. Alternatively, check whether the fuse has blown and replace it if this is the case. 4. Moisture A build-up of condensation in the kitchen exhaust fan can result in moisture dripping from it and causing staining to the surface beneath. Remove the cover after switching off the power and clean the inner surface of the cover. Check whether you can see a build up of moisture. 5. Wiring The location of a kitchen exhaust fan can sometimes cause the wiring to melt. The wires can also become loose or frayed. In this situation, the wires must be replaced. Turn off the power supply and remove the cover by unscrewing the fasteners that hold it in place. Visually check the wires for any sign that something may be amiss. If they appear to be intact and fault-free, use an ohm meter on the wires that relate to the power switch. If the resulting reading is anything but zero, then the switch is faulty and must be replaced. SPONSORED CONTENT Forget Your 401k if you Own a Home (Do This) By LendingTree Americans could save thousands by taking advantage of this government programComments Topics: projects for beginners 2 Reasons Not to Install Heat Recovery Ventilation in Older Buildings
How to Eliminate Mice From Your Home's Ductwork
How to Identify Ductwork Problems
Home Ducting Options
Troubleshooting a Furnace Duct: Banging Noises
HVAC Hacks: Energy-Saving Improvements You Can Make Yourself
How to Seal Leaky Duct Joints
Duct Insulation and and Sealing Considerations
Return Air Vent Efficiency and Proper Placement
The best way to improve the efficiency of your return air vents is to check your furnace filter. If the filter is too old, it is probably reducing the efficiency of your return vents, and you should change it. Furnace filters should be changed every six months anyway. How Do They Work? A return vent sucks in air and delivers it to the heating/air-conditioning system to be treated. The treated air is then forced out of the air vents into the rooms of the house, starting the cycle over again. Using Proper Vents Another good way to improve the efficiency of your return is to make sure the grills aren't blocking the airflow. Also, keep in mind that the size of the return vent depends upon the size of both the room and your ducts. Some large spaces might require multiple vents, and some small rooms that don't have vents might benefit from having them. In general, you want your HVAC system to have about as much return capacity as supply capacity. Proper Placement Sometimes vents get blocked by rugs, couches, or the like. Try to avoid doing this to your vents as it will reduce their efficiency. Some systems have two sets of return vents, one up high for warm air and one low to the floor for cool air. The low vents stay closed in the summer and the high vents stay closed in the winter. Shutting the Vents A popular misconception about vents is that by shutting some you can improve the efficiency of others. By closing vents, however, you raise the pressure in the ducts, causing more harm than good. Cleaning The last step in ensuring the efficiency of your return vents is to clean them on a regular basis. You can use your vacuum cleaner. Just remove the grilles and vacuum out any dust you can reach with your attachment. This is sufficient most of the time, but every once in a while you should call in professionals for a more thorough cleaning. Your return air vent plays a vital role in the cooling and heating of your home. You'll breathe a little easier with these efficiency and placement tips!
11/7/2018 1:20:40 PM • Britannia... • Answered on Nov 07, 2018
tip
How to replace oven door roller assembly in Britannia Si-9TF-SS Range
I took a chance and ordered a new roller unit although the supplier advised it would not fit my Britannia cooker S1-9TF-SS. In fact the roller assembly fitted IS the same but the hole in front of the roller assembly (in cooker body) is 2mm too narrow to remove the old unit. I removed the screw (1) holding the old assy and pushed it back into the oven side. I then filled the slot in the side of the oven, taking 1mm+ each side until new assy fitted through. I used a stiff wire hook to hold the assy so I could pull it back into place, replaced the screw and I now have a working oven door. Espares part was better than old unit and I will now replace the roller assy on the other side of door. The small oven door does not get much use so still works fine. Job took about 1hour plus and a bit of bad ******
on Feb 24, 2016 • Kitchen Ranges
Whirlpool Range Model WBP 34500. I need a wiring diagram for it please?
Unfortunately not for that model. I realize this is an old question but it is stuck and needs answering to get rid of it. :>D https://www.google.com/search?q=Whirlpool+Range+WBP+34500+wiring+diagram ..
4/9/2024 5:46:28 AM • Kitchen Ranges • Answered on Apr 09, 2024
Sirius SU1 Wall Mount Chimney Range Hood, 600 CFM. Not working at all. Replaced board?
It sounds like your new board is faulty or there are bad connections to and from it. Have you asked Sirius Helpdesk Support? https://www.google.com/search?q=Sirius+SU1+no+power ..
3/25/2024 11:28:36 PM • Kitchen Ranges • Answered on Mar 25, 2024
I am looking for a thermostat for my Samet gas stove. Having difficulty to find the part. Any replacements that might also work?
send me a picture of the thermostat body and i may be able to help. 35 years + restaurant equipment repairs. Theseafox Enterprises
3/23/2024 12:56:00 AM • Kitchen Ranges • Answered on Mar 23, 2024
How old is Whirlpool Gas Range Model #10116557A
Conflicting information in the link. My best guess is 2010 Month 11.The only way to be sure is to phone them.EDIT to Add./ I just noticed you typed 'Whirpool', I have edited your post but am not able to edit my link. When it opens, add the 'L' and press Enter.https://www.google.com/search?q=How+old+is+Whirpool+Gas+Range..
3/14/2024 2:02:48 AM • Kitchen Ranges • Answered on Mar 14, 2024
Why is my commercial oven emitting so much Carbon Monoxide?
I am a retired career chef, and had this one oven with choking CO in an airport catering kitchen. We had it serviced and it was fixed. It sounds like yours is not getting enough air mixed with the gas. Adjusting the gas is one thing but the venturi to the burners can partially block and unburned gas spills over. Remove the burner and venturi and boil it out in whatever you boil your fryers out with. Are you on mains gas or propane because the jets are different. https://www.google.com/search?q=commercial+oven+emitting+too+much+Carbon+Monoxide ..
3/1/2024 12:19:25 AM • Kitchen Ranges • Answered on Mar 01, 2024
Oven temperature not what it should be. Set at 350 and my oven thermometer only went up to 335.
That seems quite common. Place your temperature sensor, alongside the therocouple of the oven, to check its accuracy.
2/23/2024 9:36:59 PM • Kitchen Ranges • Answered on Feb 23, 2024
Where can I find a maintenance manual for a Teba TFB21Y gas cooking stove
There isn't one for the reason I stated before. Call for service. https://www.google.com/search?q=Teba+TFB21Y+service+manual The only thing available is Parts, but that is for service engineers.
Teba TFB21Y (TFB21F20) oven spare parts - FixPart
fixpart.ie https://fixpart.ie > oven-spare-parts > tfb21y-tfb21f20 Teba TFB21Y (TFB21F20) oven spare parts needed? ? 16+ spare parts deliverable. ? Next day delivery* ? Customers give us a 9.0. ..
2/23/2024 4:04:39 AM • Kitchen Ranges • Answered on Feb 23, 2024
2answers
Oven won't turn on but gas and range hood are working.
Here is text followed by a YouTube. Possible reasons why your oven won't turn on even though the gas and range hood are working: Igniter: The igniter is responsible for lighting the gas in the oven. If it's faulty, the oven won't turn on. You can check if the igniter is working by looking for a glow when you turn on the oven. If there's no glow, it's likely that the igniter needs to be replaced. Wires: The wires that connect the oven to the power source may have come loose or be damaged. Check the wires for any signs of damage or looseness and replace them if necessary. Safety valve: The safety valve regulates the flow of gas to the oven. If it's faulty, the oven won't turn on. You'll need to hire a professional to repair or replace the safety valve. Top 4 Reasons Oven Won't Turn On - Gas Range Troubleshooting (youtube.com)
2/22/2024 12:56:43 PM • Kitchen Ranges • Answered on Feb 22, 2024
Broan Nutone Range Hood RL6100C, high speed fan works but low speed does not. I am wondering if a new switch is needed?
Yes it is likely to be the switch. I have one of these as well. Remove the switch and test it with a multimeter. https://www.google.com/search?q=Broan+Nutone+Range+Hood+RL6100C ..
2/16/2024 6:29:14 AM • Kitchen Ranges • Answered on Feb 16, 2024
Where can I get a thermocouple for a Teba TFB21Y gas stove
It appears they are made in Turkey and for some reason my Malware program doesn't like their webpage
Home ' Teba Heating Stoves & Pellet Stove - We've been ...
teba.com.tr https://www.teba.com.tr Teba Heating Stoves Produce Ideal Solutions For Different Places With Environmentally Friendly, High Efficiency, Comfort, Savings, Safe And Convenient Use ... Parts https://www.google.com/search?q=teba+TFB21Y+parts Thermocouples are pretty standard. https://www.google.com/search?q=teba+TFB21Y+thermocouple ..
2/16/2024 4:10:10 AM • Kitchen Ranges • Answered on Feb 16, 2024
Britannia SIE9TLS Electric Kitchen Range Logo
19 questions posted
Top Britannia Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Britannia Kitchen Ranges
Most Popular Question
change faulty interior light
  • Kitchen Ranges
