20 Most Recent
Gbc HeatSeal Ultima 65 Laminating System Questions & Answers
Gbc heatseal ultima 65 won't turn on. It shut
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Where is the fuse?
The Circuit breaker is located on the underside of the machine near where the electrical cord goes into the laminator. West Laminating Svcs 405-324-6092
The bottom roll of laminating film will not remove.
most likely, someone has unscrewed the thumbscrews in the right side "collar". Best thing you can do is loosen both thumbscrews on the both collars, push the film on the shaft as far left as you can. then tighten both screws back down as tight as you can by hand. then grab the film and push the entire assembly to the right as it's spring loaded to the right. once it clears the keyed shaft holder on the left, just lift up and out. the right side collar screw should never be loosed. it just causes problems. West Laminating Svcs. 405-324-6092
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
