20 Most Recent
Nextbook 8" LCD 1GHz Processor Wi-Fi Tablet w/ Android 4.0 NEXT8P12 Questions & Answers
Unable to download anything keep being told insufficient memory.
Start by checking storage space available. some older versions of android have a nag of accumulating useless data in some corners of the system. You may not be able to see what uses the space, but at least it will tell you if there is space or not. To help you, i need to know if there is actually any storage left or not.
This can be found in "settings -> storage"
Note: Internal storage = the onboard storage from the factory. memory is the RAM, nothing can be saved here. So if you have an EXTERNAL micro sd put in, please provide this information.
Nextbook 8P won't reset. I have tried troubleshooting instructions with no result
you are having trouble resetting your Nextbook 8P. Here are a few steps you can try to reset your device:
- Soft Reset: Hold down the Power button until the device turns off, then turn it back on.
- Factory Reset using the Settings: Go to "Settings," then "Backup & reset," and finally "Factory data reset." Confirm the action and wait for the reset to complete.
- Factory Reset using Hardware Buttons: If you are unable to access the settings menu, you can try resetting the device using hardware buttons. To do this, you will need to follow these steps:
- Power off the device
- Press and hold the Volume Up button and the Power button
- Release the buttons when the Nextbook logo appears
- Press the Volume Down button to navigate to "wipe data/factory reset" and press the Power button to select it
- Confirm the action by pressing the Volume Down button to select "Yes" and the Power button to confirm.
If none of these steps work, the device may have a hardware issue and it may be necessary to contact the manufacturer or a professional repair service for further assistance.
I can't get nextbook to go into safe mode. How do I fix this problem
Hello Dear, this might help you go into safe mode
To get into "Safe Mode" please do the following.
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe mode: ON" or something similar.
4. If you wanted disable it, simply repeat the steps above, and you should see "Safe Mode: OFF" rather than on.
Why is it running really slowly?
You will have to uninstall every app that has been downloaded and also one by one and then test the tablet in normal mode after each uninstall apps to see if the performance issue has been fixed . If it has then the last remaining app which is uninstalled is the culprit.
