20 Most Recent Craftsman 3/4 HP Chain Drive Garage Door Opener with Keyless Entry Questions & Answers
Goes up 1 foot and stops
readjust stopping points.
9/14/2015 3:02:09 AM • Craftsman 3/4 HP... • Answered on Sep 14, 2015
The lghts on my craftsman garage door motor dont go off
I had the same problem and could not find the cause. My bulb as been removed for four years.
9/3/2014 6:34:27 PM • Craftsman 3/4 HP... • Answered on Sep 03, 2014
2answers
Garage door won't close when it's cold outside
Control board has thermal issue. Bad solder joint that contracts when cold could be the culprit. Take out board and carefully resolder every ****** connection on board.
4/3/2019 9:08:10 AM • Craftsman... • Answered on Apr 03, 2019
The opener on the wall just make a sound but the door won't go up or down
You have a gear kit broke.
6/8/2015 7:56:54 PM • Craftsman... • Answered on Jun 08, 2015
!/2 hp craftsman garage opener is closed and when you push to open it tries to close.
Your limits are damaged. Will need to replace the limit switch.
1/20/2015 8:34:53 PM • Craftsman... • Answered on Jan 20, 2015
Garage Door Opener
Adam, I don't know how old the GDoor opener is but if it has served you for long time, it's asking for retirement. These days brand new units are cheap and will give you many years of trouble free use.
4/23/2014 10:29:44 PM • Craftsman... • Answered on Apr 23, 2014
Problem with craftsman garage door opener
That is a two-flash code. It means either the wires to the safety sensors have a short in them, or one or both sensors are wired incorrectly at the motor unit. What you describe sounds like there may be a break in the wire, and the door causes the tracks to move just enough to open that break in the sensors. There could be a staple through the wires causing a short (I've done that when using a staple gun), and that could be your problem. Check your sensor wires from the motor down to the sensors themselves, and be sure they have a little bit of wiggle room. If you find a staple or something has cut the wires and caused a short, you can separate the wires a bit, and wrap each side separately with electrical tape.
9/20/2013 7:31:23 AM • Craftsman... • Answered on Sep 20, 2013
Sears garaage door remote
What exactly is the problem with the remote?
4/22/2013 2:51:56 PM • Craftsman... • Answered on Apr 22, 2013
How can i open my craftsman 315 garage door opener with a broken remote?
you might have a power failure. can you still use the wall unit?
4/2/2013 8:02:37 AM • Craftsman... • Answered on Apr 02, 2013
Genie Garage Door RC Receiver. Where is the learn button for Genie receiver model OHDH390 please?
Question edited for clarity. It doesn't look like that model number is correct 390 is the frequency of the signal. It is mentioned here are part of the regulatory approval process as a much longer number https://fccid.io/B8QOHDH390 The Learn Button is next to the bulb https://www.geniedoor.com/support/programming-instructions/garage-door-opener-remote-programming/ More here https://www.geniedoor.com/support/programming-instructions/ https://www.google.com/search?q=genie+receiver+ohdh390+learning+manual ..
4/8/2024 12:29:27 AM • Building... • Answered on Apr 08, 2024
I have a Novoferm 553 garage door system. The remotes have stopped working.
Sounds to me like a cold solder joint on one of the boards
3/31/2024 1:13:56 PM • Building... • Answered on Mar 31, 2024
How many sand and stone and cement do you need or cubic meter of concrete
A concrete mixture ratio of 1 part cement, 3 parts sand, and 3 parts aggregate will produce a concrete mix of approximately 3000 psi. (20685 kpa)
3/25/2024 5:28:07 PM • Building... • Answered on Mar 25, 2024
My DTS 600 garage door open and close very slowly
Unlikely your garage door is battery operated. The remote and wall unit yes. The remote just tells the mains operated motor to get turning. The issue will either be that everything that moves needs lubricating, motor spindle, pulleys, chain, tracks and pivots, or the carbon brushes in the motor need replacing. https://www.google.com/search?q=DTS+600+garage+door and how to fix https://www.google.com/search?q=DTS+600+garage+door+opens+slowly ..
3/13/2024 5:23:31 PM • Building... • Answered on Mar 13, 2024
How do I fix an exterior mobile home door that's not lining up properly?
Question edited for clarity. Question moved from Cars and Trucks category. Look at the corners of the doors that hold the aluminium frame together and if it is a modular door, tighten them up. If it is a solid door, adjustment can be made by shimming behind the bottom hinge with a piece of cardboard. This will move the bottom out and up. ..
2/18/2024 9:28:00 PM • Building... • Answered on Feb 18, 2024
2answers
I have roller door opener merlin430R. I can not
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button. http://www.youtube.com/watch?v=7CqMy2UfG9k
2/15/2024 10:23:37 AM • Building... • Answered on Feb 15, 2024
Garage door opens too far and ends up 2 or 3 inches into the motor housing. How do I fix this issue.
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube. If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
1/15/2024 10:16:07 PM • Building... • Answered on Jan 15, 2024
Craftsman 3/4 HP Chain Drive Garage Door Opener with Keyless Entry Logo
5 questions posted
Top Craftsman Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Building Materials
Most Popular Question
find color coded wire diagram
  • Building Materials
