20 Most Recent JVC AV-32D305 32" TV Questions & Answers
Finding a schematic for a set that age is going to be hard, you could purchase one for about 15 bucks but not sure its worth the expense. I assume this set has startup circuity on the front side of the flyback transformer, have you looked at that to make sure its working, its been yrs since I have worked on this set but if I recall they had some issues with that transistor going bad.
JVC AV-32D305... | Answered on Dec 18, 2017
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
JVC AV-32D305... | Answered on Feb 14, 2017
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    Jumbo Universal Remote Control · 8 Device ... Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote. TV Codes ... JVC, 013,054,055,060,065,067,089.‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    What is the universal control remote code for a JVC television?
    www.ask.com > Technology > Television & Video
    JVC universal codes can also be found on the instruction sheet or manual guide that comes with the remote control or television set. If these universal codes do ...
    JVC Remote Codes
    remote-codes.findthedata.com/l/163/JVC-Remote-Codes
    A list of TV, HDTV, DVD, Receiver, Audio, Amplifier and and VCR remote codes forJVC. images for codes for universal remote control jvc
JVC AV-32D305... | Answered on Nov 18, 2016
Sounds like the screen voltage is less than normal. You have to adjust it. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
JVC AV-32D305... | Answered on May 07, 2016
For a dvd player you will need to use 3 cords. The 2 cords you talk about are probably the left and right audio cords which are red and white. You will need the yellow cord for video.
JVC AV-32D305... | Answered on Feb 19, 2015
Hi big john
To answer your question;
What you have is closed caption(CC) in text mode.
To remove it ;
On the original remote there is a button labeled CC
Hit that button until you see closed caption OFF
Hope this help Cheers
JVC AV-32D305... | Answered on Oct 29, 2014
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
JVC AV-32D305... | Answered on Sep 24, 2014
Sound like your TV is in demo mode. Have you looked into the setup options?
JVC AV-32D305... | Answered on Aug 17, 2014
2970,2986,2958,2953.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
JVC AV-32D305... | Answered on Aug 15, 2014
JVC AV-32D305... | Answered on Jul 30, 2014
0024,0027,0026. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts.
JVC AV-32D305... | Answered on Jul 28, 2014
You should have its remote control to Exit the service mode. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
JVC AV-32D305... | Answered on Jul 22, 2014
Refer its user manual for details. If you don't have its remote control, you can't do this function. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
JVC AV-32D305... | Answered on Jul 17, 2014
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops or online by Ebay or Alibaba.com.
JVC AV-32D305... | Answered on May 18, 2014
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
JVC AV-32D305 32" TV Logo
216 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
remote control malfunction
  • Televison & Video
