20 Most Recent
JVC AV-27530 27" TV Questions & Answers
MY NEW JVC SMART TV WILL NOT CONNECT TO THE INTERNET.
MOVED YOU TO TELEVISION FORUM WHERE IT BELONGS
in what country, and who's TV service? what is 34mG google shows zero hits on that name 3MG (im in USA what is that)
you are posting to www , world wide and no facts told there.
who is ISP>?
there are like 1million post on here for wifi probs
billions googled.
1:you are at home i guess not work and all wifi things in the home are dead, All TVs dead, ALL PC< all cellphones set to wifi for data fail>? there tool.;
if only 1 TV fails is it over 25' or 10 meters form the home wifi router?
did you forget your wifi credentials SSID + PW????????
all TVs made have resest
we reset it and then lay in wifi credentials (yours) just like you do day 1 new TV , tell it SSID + Password
i have no idea at all how your home gets wifi. at all nor you country of service providers not the model # of your wifi router.
not if all things fail wifi in the home.
so no real answers easy.blind in a silly text box.
VERTICAL AND HORINZONTAL
maybe your tv is set to PAL mode set it to NTSC, or else your tv is out of sync.check the jungle.
Picture on tv JVC 27" AV-27530 is getting to dark
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
No voltages
Check and replace damaged component/s at its main power supply regulator [SMPS] section circuit. If you wish to get more details, check the site linked here. Surf the site in "
MOSAIC" view. It will make surf easy.
Video chroma section ic
Selecting the view option, either to
Mosaic / Time
slide, can be selected by the
drop-down list, at the top left of the
display window, will make surf easy.
You can also do a search, by type in the brand name/model number/IC
used, in the search box at the top right of the display window.
I have dishnetwork tv1 reciever is fine and shows
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on.Wealso need to know what channel your TV2 is currently on, we will do this byturning the TV off then back on and noting the channel or input that appears onscreen when the TV is powered on, if the TV is not on channel 60 or 73, tune to60 or 73. Then Access "Modulator Setup"from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture and the mode for TV2 is "Cable", change it to"Air" and change the channel on your TV2 to 60, if it is already on"Air" then change it to "Cable" then change TV2 to channel73. If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. The next thing we want to check is the connectionon the back of your receiver labeled "Home Distribution", this cablecarries the picture all the way to your TV2. Start by removing the connectionand screwing it back in, make sure all the connections going to your TV2 arehand tight. These steps should get your TV2 up and running.
We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
JVC TV Blue screen No remote
To select the source you must have its remote control. There is no TV/AV source select button at the front panel of this TV.
The sound does not comes from my tv
If its the set indicated here not too many easy possible reasons:bad speaker in setSpeakers on rear of set are switched to external (slide switch may be there)A bad headphone socket if therelast is a problem in the sound circuit which would cost more to fix than the set is worth,
Setting up external speakers
Only can be done if the set has connections on the rear for this--installing or adding speakers can damage the set instantly.
