20 Most Recent JVC AV-32260 32" TV Questions & Answers
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
JVC AV-32260 32"... | Answered on Apr 07, 2019
If its totally dead, then its either the main board or power supply
JVC AV-32260 32"... | Answered on Nov 28, 2017
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
JVC AV-32260 32"... | Answered on Aug 12, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
JVC AV-32260 32"... | Answered on Jul 09, 2016
check your tv settings for standby mode. It may be set for 10 minutes to turn off if there is no tv signal like a power saver feature. It may not recognize the computer as a signal input. If I put my tv on a channel with no signal, it will turn off automatically after a short time. The same happens if I have it in video mode for the vcr and if the vcr isn't playing, after a short time the tv will turn off.Good luck
JVC AV-32260 32"... | Answered on May 26, 2015
It will be best for you to download the user manual to your TV. www.retrevo.com/
Check this site to download it for free. It has all details. Electro help
JVC AV-32260 32"... | Answered on Oct 24, 2014
You will need to adjust the audio on your TV. In this case I would shut down the bass boost and shut down the surround sound. Surround sound is sometimes called expansion sound. These are located on the menu under audio control. You may be satisfied with operating the TV in mono sound. Try this and see if this is better.
JVC AV-32260 32"... | Answered on Apr 10, 2014
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
JVC AV-32260 32"... | Answered on Jan 28, 2013
Electrolytic cap in low voltage supply
JVC AV-32260 32"... | Answered on Jan 03, 2013
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
JVC AV-32260 32"... | Answered on Oct 01, 2012
Greg! you may have bad connections on the main board, flip the board over and carefully check the solder points, flybach transformer, horizontal driver transformer, video circuits to name a few, if you are handy with soldering iron all the better, some solder joints are hard to spot so use iron anyway. Make sure you resolder the parts that I have outlined even if the solder looks good.
JVC AV-32260 32"... | Answered on Sep 30, 2012
JVC AV-32260 32" TV Logo
79 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
necesito el codigo de la tv jvc gowin
  • Televison & Video
