20 Most Recent JVC AV-27020 TV Questions & Answers
2answers
I have a Murphy 16855BKDVDLED
Hlo sir my TV murpy keyboard lock plz help plz solution
8/14/2021 4:58:59 PM • JVC AV-27020 TV • Answered on Aug 14, 2021
3answers
Help! How can you unlock a pin on a TV that you don't know?
Tried unplugging it for five minutes then plugging it back in? It resets the software.
2/7/2019 2:09:35 AM • JVC AV-27020 TV • Answered on Feb 07, 2019
JVC AV-27020 (110 volts) plugged into 220v outlet
Taking the tv to a local repair shop is probably much cheaper than having an engineer call at your house, though some self employed guys don't charge call-out. Try your local classified directory. It might be as simple as a fuse. You should be able to check that for yourself or engage a handy neighbour. You should be able to download a manual from the manufacturer's website or just try a google search. Whether it is a lost cause or not is not really predictable.
10/22/2017 8:58:54 PM • JVC AV-27020 TV • Answered on Oct 22, 2017
0answers
manual
AV-27020 TV Manual
JVC Televison & VideoUploaded on Aug 15, 2013
I have a GE remote and an I'Art JVC tv, cannot get remote to work.
Setup codes for JVC with GE remote control are:0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
7/29/2012 4:41:28 PM • JVC AV-27020 TV • Answered on Jul 29, 2012
There. Is a channel lock
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code. [2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password. Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
5/31/2011 9:20:43 PM • JVC AV-27020 TV • Answered on May 31, 2011
Occationally turn on
This is an indication of out-of-regulation in the power supply section. This is cause by leaky/dried electrolytic capacitor in that section. It will dropped the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst until the unit will not even power up. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky/dried capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
5/20/2011 2:02:48 PM • JVC AV-27020 TV • Answered on May 20, 2011
I have a blank black rectangle on my screen. When
Tv still have Close Captioning functions is on.Tries tv remote button like CC turn off all CC1,2,3 to all off.Or goto tv menu goto Close Captioning turn off all CC1,2,3 or Text 1,2,3 to all off.Should stop the rectangle square appearing.
3/2/2011 5:55:42 AM • JVC AV-27020 TV • Answered on Mar 02, 2011
Black solid square keep popping up on my screen
Get the remote, press menu, scroll down to captions, press right 1,2,3,off when cursor is over off press enter on your remote, that should get rid of the black box.
2/17/2011 12:28:10 AM • JVC AV-27020 TV • Answered on Feb 17, 2011
My JVC AV-27020 TV that
the problem is the vertical height adjustement but usely you dont need to adjust this setting its inside
the set , thats is probably a capacitor in the vertical deflection circuit chips but you can disconnect the set and open it and look for a mini control wheres its write v height because the guy sale you the tv should have a problem with this;i highly recommend that you dont do wath i say but call a tech at home and make it fix its an hour jobs about
its not verry expensive...
hope that will help you ps if you decide to open it and fix that by your self watch you have very high voltage inside it can arm you seriously
regards allan ,pro tech..
10/3/2010 3:49:34 PM • JVC AV-27020 TV • Answered on Oct 03, 2010
CODES FOR CHUNGHOP UNIVERSAL REMOTE
try these
JVC 0653 0053
0190 0036
0683 0192
0193 0371
0218 0606
0418 0093
1923
Please rate my help++++Thyanks for using FIXYA
6/9/2010 8:12:36 AM • JVC AV-27020 TV • Answered on Jun 09, 2010
I have a 27 in JVC TV model AV-27F577. The green
there is a power problem up to the screen given the make model and age our company would write it off
sorry
4/24/2010 6:07:32 AM • JVC AV-27020 TV • Answered on Apr 24, 2010
BLACK SCREEN. I DO HAVE SOUND
If the TRC filament is light, turn a little clock wise the fly back knob "SCREEN" and if you see a horizontal line at midle of the screen the trouble is in vertical stage.
3/20/2010 3:31:30 AM • JVC AV-27020 TV • Answered on Mar 20, 2010
The timer on button flashes
The timer light blinking indicates a failure in the TV set. Either the vertical circuit or horizontal circuit has failed and needs repair. It actually has nothing to do with the timer circuit.
In my experience its probably a vertical output chip, smalla capacitor and zener diode. There may also be an open resistor.
Cost to repair in the 50-75 dollar range usually
2/15/2010 5:02:55 PM • JVC AV-27020 TV • Answered on Feb 15, 2010
There is a black box at the bottom of the screen
easy. get your tv remote not any other remote. the remote that came with the tv. no other remote will fix. the remote that came with tv from factory. go into menu. go to closed caption mode and select off. easy
11/13/2009 2:41:18 PM • JVC AV-27020 TV • Answered on Nov 13, 2009
I was playing a game and it made a sound then shut
Something shorted in the set, possibly the horizontal output transistor or a power supply diode. The reason it starts blinking again after plug in is because JVC try to come back on if they were on when the problem started. In other words, if it quit while it was playing it will always be in the on position until the problem is repaired and it can be turned off normally. Have a shop check it out for you. There are a lot of things that can cause one to go out. Thanks
11/1/2009 11:50:31 PM • JVC AV-27020 TV • Answered on Nov 01, 2009
JVC AV-27020 TV Logo
Popular Tags
55 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
ge remote 39 art jvc tv cannot get
  • Televison & Video
